It is currently Tue Sep 29, 2026 2:52 am
Post Posted: Tue Oct 18, 2011 3:01 am
Are there any difference between timing belts and tensioners for all the g13b engines?
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Post Posted: Tue Oct 18, 2011 3:14 am
yes. gti?
mk1 is much narrower and cam belt diffrent pullys, mk2/3 are wider..
g13a
square cut belt, 5bolt bottom pully, multi rib pully
g13ba
round cut belt, 4 bolt bottom pully, Vbelt pully
Post Posted: Tue Oct 18, 2011 1:53 pm
It actually depends on the year - and not all G13b engines are 16v DOHC GTi engines.
I have a G13b here (which I've had from new) that is an 8V SOHC engine - with square cut timing belt, four hole bottom pulley & a multi-rib accessory belt.
I also have a G13b (that I know the history of) that is a 16v DOHC engine with round cut timing belt, five hole bottom pulley and multi-rib accessory belt.
Users browsing this forum: Google [Bot] and 163 guests
