It is currently Mon Sep 21, 2026 2:59 pm
Post Posted: Tue Oct 18, 2011 3:48 am
Is there a right or wrong way to remove welsh plugs.
Any danger of knocking them in too far in process?
I had a $1 welsh plug kill a new engine in the Little Desert a while back.
So this new motors getting all new ones.
Especially in hard to reach spots.
Post Posted: Tue Oct 18, 2011 4:03 am
You can push em in too far but you need to be pretty heavy handed
I like to hit one side with a punch so it pivots and the opposite side pokes out, then grab it and pull it out with some pliers
then to install find a socket that fits sungly in the plug and put some 4j sealant around the outside and tap it in slowly
Post Posted: Tue Oct 18, 2011 4:13 am
If Royce's extraction method doesn't work, you can drill a hole in the plug and lever out with a screwdriver. They're not hard to get out when the motor is on the floor
Post Posted: Tue Oct 18, 2011 4:27 am
Many thanks guys, thats within my grasp.
They "look " ok from outside, and feel ok with a tap,
but I never want to work on it again,
or have another motor die on a trip,
so I will change them.
Also got new rad hoses, and stuff.
Will do timing belt and anything else hard to reack when assembled.
Time to stop for the day, now, had enough, and I hungry :)
Post Posted: Tue Oct 18, 2011 4:33 am
It's always a good idea to do all these things when you're doing a motor swap, as you say it saves pain and heartache down the track
Post Posted: Tue Oct 18, 2011 4:38 am
Modifying is fun.
Fixing isn't.
So to motivate myself,
I will try to make it better than it was before :)
Users browsing this forum: No registered users and 135 guests
