It is currently Mon Sep 21, 2026 6:52 am
Post Posted: Tue Oct 18, 2011 10:00 pm
Hey guys,
I am currently installing a couple gauges on my G16B engine...
Does the oil temperature sensor go into the side of the oil pump?
and does the oil pressure sensor go next to the stock oil sensor?
When I tried fitting the oil temp sensor the fitting that came with the kit stops the sensor from falling out, but it can still be pushed further in? Leaving it not sealed.... I find this really weird as the only way it could work is for the sensor to be pushed up against something hard in the pump to stop it from going further into the block/pump...
I am using speco gauges...
Post Posted: Tue Oct 18, 2011 11:49 pm
To fit both oil pressure & temperature sensors I would suggest you get a sandwich adapter - it fits between the block and the oil filter.
Post Posted: Wed Oct 19, 2011 5:46 am
What is a sandwich adapter mate?
Post Posted: Wed Oct 19, 2011 6:16 am
it's a adapter that turns ham cheese & bread into toaated ham & cheese sandwiches. :crazy:
nah, it's one of these jiggers. it screws on where your oil filter goes & then the filter screws onto that & it has a couple of threaded holes for sensors or to run an external oil cooler.
Post Posted: Wed Oct 19, 2011 8:05 am
Where do I get one of these from? Is it really called a sandwhich adapter haha
Users browsing this forum: Google [Bot] and 196 guests
