It is currently Sun Sep 20, 2026 10:58 pm
Post Posted: Thu Oct 20, 2011 5:22 am
hey guys got a 97 g16b in my sierra. now i took it to my local mechanic to get it tuned after the motor was wired up. he set my timing to 2deg. i seem to remember reading somewere that it should be at 8 deg but i cant turn the dizzy anymre as its at its limit. so do i pull the dizzy out and try and get it to 8deg or leave it were he set it?
Vehicle: 85 hightop drover
Post Posted: Thu Oct 20, 2011 5:45 am
Stock timing is 5deg -+1deg
16valve efi hightop drover
Post Posted: Thu Oct 20, 2011 6:05 am
Pull the dizzy out and move it a few teeth over so you are in the middle of the adjustment again.
FSM says 5*BTDC base timing with the diagnostic plug bridged. I've just set mine till she starts to ping and brought her back a few degrees.
Dan
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Thu Oct 20, 2011 6:24 am
Dan
Work's a treat!!! :P
Post Posted: Thu Oct 20, 2011 6:36 am
pulled the dizzy out a million times adjusting it but i still cant get it to 5deg. the closest i can get is 2 and 11.... might just get a round file and file a bit out of the dizzy so i can turn that tiny bit more..
Post Posted: Thu Oct 20, 2011 6:43 am
Something not right then. You should be able to get 8-10 in the middle of the adjustment
Post Posted: Thu Oct 20, 2011 6:57 am
what could be wrong? like i said iv pulled it out a million times but everytimei do i haveto turn it to the full adjustment to get 2 or 11
Post Posted: Thu Oct 20, 2011 6:58 am
i rekon the mechanic must ov had the same problem so he just left it at 2deg. would filling the adjustment out a tiny bit work or not a good idea, theres a fair bit of meat on the sides.
Post Posted: Thu Oct 20, 2011 6:59 am
be gentler and pull it slowly till its jsut holding and youll feel it move over a single tooth
Post Posted: Thu Oct 20, 2011 7:35 am
i can feel it moving 1 tooth and still either wont start or be way way advanced
Users browsing this forum: No registered users and 222 guests
