It is currently Mon Sep 21, 2026 5:39 am
Post Posted: Fri Oct 21, 2011 4:23 am
How do you tell the difference between mk1 mk2 and mk3 gti engines
92sierra ht 33s 5in lift 2in zorst gti powered
Post Posted: Fri Oct 21, 2011 4:56 am
Not sure if you need to be signed up
http://www.redlinegti.com/forum/viewtop ... en+mk1+mk3
http://www.redlinegti.com/forum/viewtop ... 15&t=25041
MK1 has a different intake/fuel rail and the air flow meter on the intake manifold on top of it while MK2/3 has it on the airbox (if that makes sense)
The thermostat housing is different also
MK2/3 are pretty much identical (computer on MK2 is 128rom while MK3 is 256....few other small differences in the loom etc)
Im sure there are alot more things and people on here will be able to help you ou.....maybe PM jonno_racing as he know alot more....he's been tinkering with these engines and doing a few conversions
Also have a look on redlinegti.com forum
If you're going to do a conversion into a sierra...try finding the MK1 as it's abit easier in regards to the dizzy setup
Vehicle: Tin Top
Post Posted: Fri Oct 21, 2011 6:03 am
Have just done a MKIII conversion and found it straight forward enough.
All information you need is online, GTI Manuals and wiring diagrams etc.
Can only recommend this conversion, better power, economy and fun.
Am just fine tuning mine now but very happy.
GO the GTI :D
Post Posted: Fri Oct 21, 2011 7:20 am
MKI is out of the 88 modle boxy types.... and MKII is early mid 90's and MKIII is late 90's ?? Im not 100% sure but I think that is roughly right...Someone correct me?
Users browsing this forum: No registered users and 174 guests
