It is currently Sat Aug 01, 2026 11:58 pm
Vehicle: 95 sj70 and 78 lj81
Post Posted: Fri Oct 21, 2011 7:50 am
Doing some work on the zook this week and nearly had it all back together and the wiper motor didnt work. I checked it before I locked the windscreen back but now its failed. I pulled it out and checked on the bench still dead except for if I put power to the yellow terminal and a blue one. Any clues, can I fix it or is it bin time?
Post Posted: Fri Oct 21, 2011 8:06 am
Earth wire???
Post Posted: Fri Oct 21, 2011 9:12 am
Yeah thought that. I've got it out on the bench and still no good
Post Posted: Fri Oct 21, 2011 9:16 am
were you testing it with water in it to cool it???
Post Posted: Fri Oct 21, 2011 9:20 am
Post Posted: Fri Oct 21, 2011 10:19 am
no I just tested it in the fridge you fool
Post Posted: Fri Oct 21, 2011 10:22 am
Lol
Vehicle: 4wd
Post Posted: Fri Oct 21, 2011 10:35 am
Wiper motor not washer motor :lol:
Watch out or you'll get sued.
Vehicle: SJ80, SE416
Post Posted: Fri Oct 21, 2011 11:49 pm
Not too sure about Zuk specifics, but normally only 2 of the wires are +ve and -ve - one of the wires is the contact that signals when the wiper is at it's rest position for the wipers to stop in the correct place when switched off. If the motor works on the bench, check the linkages to the wipers haven't all rusted/frozen up.
Post Posted: Fri Oct 21, 2011 11:56 pm
hah- my bad.... i just had a washer motor die a little while ago - when it wasnt pulling water through it got super hot (it was jammed with rubber from the seal around it that had perished and got sucked in).
Post Posted: Sun Oct 23, 2011 7:26 am
Sorry alien just thought you were trying to be smart,
So the story goes,
I had just replace the windscreen surround ( thanks Stekky), As it must from a slightly diff model the wiper arms are diff lengths and jammed the motor and blew the fuse. I also put toooo long bolts in the top 2 wiper motor mounts which also jammed the actuator arm. So now with the correct bolt length , the correct arms for said windscreen and a new fuse all is good.
Users browsing this forum: No registered users and 1208 guests
