| G16B Wire colour identification http://auszookers.com/forum/viewtopic.php?f=5&t=27036 |
| Author: | howie4444 [ Sun Oct 23, 2011 5:25 am ] |
| Post subject: | G16B Wire colour identification |
Hey all. Pretty new to the forums thing so easy on me. So i've got a nice little 92 Sierra with the G16B conversion which had already been done by a previous owner. I'm putting an adaptronic 440 ECU in the old girl but i'm looking for some help with wire identification... I've seen a few diagrams for http://www.suzukiinfo.com/ but at a glance, they don't match up to my wire colours. They must be identification for G16B's from other countries maybe. Either way, if someone out there has a list of all the ECU pins and what they do, that's probably what i need (eg. pin 4-water temp, pin 5-Throttle pos sensor etc etc) Engine is a G16B, twin coil, waste spark, SOHC, 16V... Year model and from what vehicle is unknown. It uses a MAP sensor not a MAF sensor and no dizzy. unlike most of the diagrams i've found which tend to show a MAF sensor and even a dizzy... Any help appreciated. Howie. |
| Author: | BlueSuzy [ Sun Oct 23, 2011 5:31 am ] |
| Post subject: | Re: G16B Wire colour identification |
Where is the top water outlet? Back of head or coming out of the intake manifold? Sounds like a later GV 2door (rareish) or Baleno motor. |
| Author: | howie4444 [ Sun Oct 23, 2011 5:35 am ] |
BlueSuzy wrote: Where is the top water outlet? Back of head or coming out of the intake manifold?
Sounds like a later GV 2door (rareish) or Baleno motor. Thermostat housing is mounted on the back of the head... And yes, i was told it was a baleno motor but still not 100% sure. |
| Author: | BlueSuzy [ Sun Oct 23, 2011 5:41 am ] |
Yep. Its a 98+ Baleno motor. Also Esteem in other markets. Runs a crankangle sensor also. |
| Author: | BlueSuzy [ Sun Oct 23, 2011 5:46 am ] |
May be of help http://www.ptjau.com/images/sierra/bale ... ringv1.pdf |
| Author: | howie4444 [ Sun Oct 23, 2011 5:46 am ] |
yes that's correct. definitely has a crank angle sensor |
| Author: | CairnsZook [ Sun Oct 23, 2011 5:48 am ] |
Try this link. http://www.redlinegti.com/forum/vt.19261.htm |
| Author: | howie4444 [ Sun Oct 23, 2011 5:48 am ] |
Thanks... I'll do a cross reference some time this week to see if colours match up. Legend. |
| Author: | BlueSuzy [ Sun Oct 23, 2011 5:56 am ] |
http://www.redlinegti.com/forum/viewtop ... 09#p358409 This may help also. Pinouts for a different model adaptronic. They have alot of baleno engine tech over there as its mainly turbo'd roadcars. |
