It is currently Sun Oct 25, 2026 10:27 am
Post Posted: Mon Oct 24, 2011 7:17 am
Can some one who has bought the manual hub rings of bigjimny.com, tell me the measures of the rings.
The outside nd inside diameter etc. And how thick
Thanks
Post Posted: Mon Oct 24, 2011 8:05 am
You gettin some made?
If so would you be willing to make more?
Post Posted: Mon Oct 24, 2011 8:10 am
I'm gonna try at work. I could get some but there out of stock nd need to fix the Jim.
If I get the measurements I can bore out the solid bar to the size and slice it into rings
Post Posted: Mon Oct 24, 2011 8:14 am
let me know if you do.. Will be keen.
Post Posted: Mon Oct 24, 2011 8:22 am
I'll see what I can do
Post Posted: Mon Oct 24, 2011 8:34 am
Can't you just buy AVM hubs of the self that fit with out mods? :?
Post Posted: Mon Oct 24, 2011 8:46 am
Yes but I have 3sets off hubs sitting here nd like to do some thing with them.
Will be able to do the rings for 1/4 of the price of hubs
Post Posted: Mon Oct 24, 2011 8:04 pm
You can get the inside and out side measurements of the hobs themselves and the thickness is the same as the flange on the hubs - Have a look at the fitting sheet and you will see what I mean
http://www.bigjimny.com/images/document ... l_hubs.pdf
Post Posted: Mon Oct 24, 2011 10:55 pm
Thanks Tony I'll have a look
Post Posted: Tue Oct 25, 2011 9:44 am
thats ALOT!!!! of work!!
Not to mention you will have to lap both surfaces once cut so that they are flat, otherwise you won't be able to make a seal.
FYI I have 20 set on order now. I've been working on a few projects in my AZ absence. Should be cheaper than bigjimny too.
But just incae you NEED to have a go yourself, they are 8mm thick.
Post Posted: Tue Oct 25, 2011 10:27 am
Yea I relies I will have to lap both side. Reason is that I need my Jim back on the road. It's been three weeks up on jack stand. Idk when bigjimny.com will have them back in stock.
You wouldn't have a estimate time you will have them ready to sell?
Post Posted: Tue Oct 25, 2011 11:06 am
Due date on the order is 14th of November. I really hope its sooner though, as I am waiting on a heap of other parts in that order for stock.
Post Posted: Tue Oct 25, 2011 8:16 pm
yaaaaay some TSOR stuff for jimnys Armsup , finally some love from mr Fat
8O is this the end of the world??.. do Im gonna die or sumething?
haha
:P
Post Posted: Tue Oct 25, 2011 11:58 pm
I dont even run the spacers with Free-wheeling hubs. Just pull of your hubs remove the circlip and metal flange then grind that lip down. Vitara / Sierra hubs then just fit straight on.
I Busted 3 sets of hub bolts with the spaces on 34s but now they are shorter so less side loading on the bolts.
Post Posted: Wed Oct 26, 2011 12:18 am
8O I do not want to touch my car with a grinder, I rather do it the right way. Also I will never be running 34s so I won't have that problem
Post Posted: Wed Oct 26, 2011 12:21 am
I think "The Right way" would be to use the hubs that were designed and built for the vehicle not some others that need adapters or modification.
Post Posted: Wed Oct 26, 2011 1:06 am
That's true but I'm sick of the vacuum hubs stop working every time I go for wheel.
Post Posted: Wed Oct 26, 2011 2:50 am
Just buy avms....
Post Posted: Wed Oct 26, 2011 3:09 am
monkey wrote:
Just buy avms....
Rings are cheaper haha
I found some scrap metal today. It's half done already Armsup
Post Posted: Wed Oct 26, 2011 4:54 am
Does the inside diameter have to be the same as a Sierra hub or does it have to be the same diameter as the thing that sticks out of the Jimny spindle.
The scrap solid bar i found has been bored out to the same ID of a Sierra hub already
Vehicle: 85 SJ413
Post Posted: Wed Oct 26, 2011 8:02 am
I have some Jimny hub spacers in stock. They come with cap screws, spring washers and new cone washers. $50 AU + $10 AU shipping.
Ben
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Post Posted: Wed Oct 26, 2011 8:04 am
nice work ben 8)
Post Posted: Wed Oct 26, 2011 8:26 am
Ben you have a pm
Users browsing this forum: Google [Bot] and 168 guests
