It is currently Sat Oct 10, 2026 8:33 am
Post Posted: Wed Oct 26, 2011 2:50 am
Hi
I just rang ARB and they tell me lockers are not made for my Jimny.
Is this true?
My Jimny is a 2010 1.3 vvt and im sure ive seen them in them before.
If they are available what part no should i be quoting to them?
Unrelated topic they quoted me $1100 for a 40mm OME lift does that seem reasonable?
Post Posted: Wed Oct 26, 2011 2:51 am
i'd ring another store...
Vehicle: 2001 Jimny M13A
Post Posted: Wed Oct 26, 2011 3:05 am
And the switches fit too (2001 M13A Non VVT).........
Vehicle: 03 Jimny
Post Posted: Wed Oct 26, 2011 3:07 am
Rear is rd88 should be, front I'm not sure
Post Posted: Wed Oct 26, 2011 3:18 am
Found the old paperwork..
The Front in mine:
RD87
Suzuki Jimny, FR, 8 Bolt RG
Part No. 210287
Post Posted: Wed Oct 26, 2011 4:03 am
I was quoted recently $2,400 for the rear and $1,650 for the front plus diff lapping if needed from ARB at coopers plains south of Brisbane
Vehicle: SJ80, SE416
Post Posted: Wed Oct 26, 2011 4:13 am
$4050? WTF?
Vehicle: 03 Jimny
Post Posted: Wed Oct 26, 2011 4:19 am
Reubs wrote:
$4050? WTF?
I think he ment $2400 for front and rear. That's how much they are for both
Post Posted: Wed Oct 26, 2011 4:31 am
$4000 is $1500 cheaper then what they want here.
Post Posted: Wed Oct 26, 2011 5:11 am
ARB Ballarat just quoted me $3500 fitted including premium compressor tire inflator and pressure guage.
This seems ok to me.... Any thoughts
Vehicle: SJ50 hardtop!
Post Posted: Wed Oct 26, 2011 5:26 am
Did you ask for a breakdown on the quote?? IE how much of that is labor related.
In some cases it's easier to buy the lockers yourself and drop the 3rda in to get fitted and tapped. If your even the slightest bit mechanically minded, you should be able to fit and wire the compressor in yourself and run the lines.
Might be able to save some cash if you want to give it a go.
NT SJ50
Post Posted: Wed Oct 26, 2011 5:56 am
[quote="Bucket"]Did you ask for a breakdown on the quote?? IE how much of that is labor related.
Might be able to save some cash if you want to give it a go.[/quot
Ok they quoted $1580 each front and rear fitted and $500 for the compressor than he said $3500 for the lot. This was a verbal quote.
Yes I could easily handle the compressor and plumbing but not sure about the lockers. If they came with detailed instructions I could prolly do them aswell but unsure how that affects the warranty.
Vehicle: 03 Jimny
Post Posted: Wed Oct 26, 2011 6:04 am
Thats way to much still. I got everything including fitted under 3k
I would defiantly go to another arb store
if you quote the prices from Low range offroad to Penrith ARB, they almost match the price :)
Stocker
Vehicle: 1985 Holden Drover
Post Posted: Wed Oct 26, 2011 6:09 am
Or just bullshit a price to ARB and theyll match it too :lol:
What i'm saying is you could get the guys to fit the actual locker itself and tap the barb into the 3rd. Then all you would have to do is put the center back into the housing, wire in compressor and switches and run the air line.
Might save you some coin.
If I remember rightly, in Sydney the shop I was working for was only paying about $950 or so I believe. Obviously it was a trade price, but gives you an idea. $1200ish retail each??
NT SJ50
Post Posted: Wed Oct 26, 2011 6:17 am
i'm guessing the $500 air compressor is probably the new fancy twin cylinder one, there is a $300 option.
Post Posted: Wed Oct 26, 2011 7:33 am
Just got a quote to install air locker.
$150 with me removing the diff.
I'll do all the wiring and ancillary work.
Install with complete diff rebuild $550
SS
Post Posted: Wed Oct 26, 2011 7:44 am
I don't think the part number is rd88 any more....
Post Posted: Wed Oct 26, 2011 7:49 am
Correct. It's now RD208
And RD 87 is now RD207
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Oct 26, 2011 9:29 am
I'm picking up my compressor and tyre inflation kit up tomoz for $335
Each locker fitted by ARB is around $1500
I'm taking out my centres and taking them to my TJM store and they're gonna charge me about $1150 a locker and $200 to fit them.
What you got quoted is rubbish! I'd up them about it!
Post Posted: Fri Nov 25, 2011 3:29 am
Can someone confirm these part numbers for a 2010 jimny.
ARB quoted....
Rear RD 208
Front RD 118
Does anyone no for a fact about these numbers for 2010 1.3 vvt jimny
Users browsing this forum: Google [Bot] and 216 guests
