It is currently Tue Oct 20, 2026 1:06 am
Post Posted: Wed Oct 26, 2011 4:56 am
Bugger, just started assembling the Vit at last.
But could not bolt engine to auto,
as the torque converter would jam,
with about a 3mm gap.
I suspect a spacer or similar was used from wrong engine.
Think I used all the auto bits from mine.
I used my flex plate, and torque converter.
New engine came with a flex plate, too, but it was a bit bent.
So will have to remove engine and have a look see.
Thought about trying to do it in engine bay,
but probly faster to take it out first.
Anybody have any ideas what else to look into.
Post Posted: Wed Oct 26, 2011 5:15 am
Is the torque converter right in? It may have come out a little bit. If you push on it while turning it around it might just pop back in a bit. May take a few turns
Post Posted: Wed Oct 26, 2011 5:30 am
Yes I been doing that all arvo.
Pulled motor off the auto a few times.
Thought I 'd found problem, when I found a blob of grease on the splines.
It did go on better when I cleaned splines.
I do remember picking what looked to be the best spacer for the flex plate.
Hence my wondering if thats it.
I'll measure up properly termorra.
Oh well first auto I ever worked on,
so I am allowing myself a few oopses.
Fresh brain tomorrow will probably solve it.
Post Posted: Wed Oct 26, 2011 5:32 am
or an angle grinder :twisted:
Vehicle: LJ20 LJ50
Post Posted: Wed Oct 26, 2011 5:36 am
Some engines run a bearing in the back of the crank to support the input shaft of the manula boxes. The autos run a bush in the middle of the crank.
But as Shep said if they are both autos then it may be the torque convertor not going all the way on. Sometimes there is three clicks in.
And also is the flex plate on the right way. I have done these twice. On different cars.
Camels have nice toes
Post Posted: Wed Oct 26, 2011 5:52 am
I been taking photos to make sure things go back the same way.
Tho I guess that assumes it was right to start with.
Torque converter bolts to flex plate, and slides in with motor.
Vehicle: WR250F/Jeep XJ
Post Posted: Wed Oct 26, 2011 7:34 am
chris try and put the torque converter onto the auto input shaft first. It's vitally important that you make sure the torque converter is properly seated all the way in. If it's not you risk destroying the pump on pretty much the first start of the motor and then you'll be up for big bucks getting the auto pump rebuilt.
Had a mate recently do this to his commo V6 in a hilux. ended up costing him about $800 to fix!
You can bolt the torque converter to the flywheel once the motor is bolted on. This means you can also check the clearance in the inspction panel on the bottom part of the bellhousing, there should be at least 1-2mm of play in the torque converter to flexplate union. If it's hard up against it you might need to change the spacer or check the converter again.
LIKE US ON FACEBOOK - KPD4x4
Post Posted: Wed Oct 26, 2011 7:41 am
Thanks mate, gives me a good starting point for tomorrow.
cheers
Post Posted: Wed Oct 26, 2011 7:51 am
I misunderstood what you meant,
it is now a bit clearer, thanks
Post Posted: Wed Oct 26, 2011 7:57 am
put the converter on the flex plate loose, there is 2 bits that has to engage on the converter, some times it needs to move a fair bit to line up.
when its all the way home and box it tightened up turn the engine and converter over 5 or 6 times, that will center it on the flex plate.
This will be so much easier than what I was trying.
Never entered my head that I could access the flex plate bolts underneath.
would have been easier to pull out that way, too.
Oh well, I learning lots a new stuff :)
Post Posted: Wed Oct 26, 2011 8:00 am
Cool, thanks.
I'll be an auto expert by end of tonight.
Post Posted: Wed Oct 26, 2011 8:01 am
I don't want to hijack your thread Christover1 but...
I recently had an auto gear box installed (I didn't want to do it on my garage floor)
I noticed the inspection panel when I was under there. Does it usually have a cover on it?
It looks odd so I suspect they haven't put it back on but I can't see any bolt holes or anything to mount a plate. I'll have to go back and ask for it if it is indeed missing.
Post Posted: Wed Oct 26, 2011 8:05 am
Mine had a cover, held on by 2 tiny bolts, 6mm I think, uses 10mm spanner.
Also cover would not come off until the bracing mount came off.
Not sure if the extra braces are a Vit thing, or a auto thing.
Many mechanics leave them off, lose them, whatever, probably why new ones are sold by lowrange etyc.
Post Posted: Wed Oct 26, 2011 8:18 am
Check your not doubled up on your locating dowel's....for bell housing & block..
Post Posted: Wed Oct 26, 2011 8:21 am
Well I wish I'd asked before I started work, :roll:
but had no idea it would be different to a manual :crazy:
Post Posted: Wed Oct 26, 2011 8:22 am
Have done that before, tried all night to fit a gearbox, many swear words and curses :evil:
So yep, checked that more than once :oops:
Post Posted: Wed Oct 26, 2011 8:27 am
No, converter has to mate in the pump drive in the g/box first, then stick the eng in & bolt con to flexing plate..
Post Posted: Wed Oct 26, 2011 8:30 am
Thanks mate. I will head back and see if I can find one.
Good luck with your install :)
Post Posted: Wed Oct 26, 2011 8:36 am
cheers, worked that out from eveyones help.
Will certainly be a lot easier that way, too.
Thought I had researched this thouroughly, but clearly not :oops:
Post Posted: Wed Oct 26, 2011 9:31 am
I just assumed you were doing it that way :lol:
They take a few turns and a bit of pressure to seat properly on the input shaft of the gearbox. You will see when it has seated properly
Post Posted: Wed Oct 26, 2011 9:35 am
Cool thanks, wasn't easy to get off, so assumed on could be also be tricky.
Tomorrows another day. And now I know a little bit more than everything ;)
Post Posted: Wed Oct 26, 2011 11:30 pm
I had to pull engine out back on to floor,
to safely remove the torque converter.
Torque converter did go on all the way onto out put of auto,
with no interference.
Altho fitting correctly was a hell of a lot easier,
it still didnt work.
So out with the engine again (I'm getting good at it)
Spacers for flex plate are different.
Not so much the thickness of inner spacer,
but the length of the centre bit.
One outer spacer was also thicker.
Maybe thats the problem.
It could be fouling on the centre bit.
I'll put it together with the thinner spacers,
and the thinner headed nuts,
and try again
Post Posted: Thu Oct 27, 2011 12:04 am
Changing them round didn't seem to make any difference,
was no catching or interfence going on.
Will measure the bits flex plate bolts to, see if anything there is different.
Post Posted: Thu Oct 27, 2011 3:03 am
I am trying it this way now,
as converter keeps falling out of its position while engine goes in.
I measured all me spacers, not much in it, so used the thinner anyway.
Post Posted: Thu Oct 27, 2011 3:46 am
This way worked, 4 bolts are in and it can still rotate :)
Thank you all,
everyones advice made it go together easily this time.
:woohoo:
Post Posted: Thu Oct 27, 2011 3:47 am
PS I must remember to do up the flex plate bolts, soon as I can get underneath.
Post Posted: Thu Oct 27, 2011 4:16 am
:woohoo: :woohoo: :woohoo:
Post Posted: Thu Oct 27, 2011 4:28 am
Only took 25 minutes from garage floor, to 4 bolts inserted. :D
What the heck was I doing for the last 2 days :oops:
Just swept all the tools off driveway and into the garage,
closed garage door, and walked away....
The rest can wait for the morrow.
Its beer oclock now :cheers:
Vehicle: 93 Sierra
Post Posted: Thu Oct 27, 2011 5:23 am
Armsup
Users browsing this forum: Google [Bot] and 345 guests
