It is currently Mon Nov 02, 2026 2:43 am
Post Posted: Wed Oct 26, 2011 6:53 pm
will a 1 litre soft top complete body fit on a 1.3 rolling chasis
Post Posted: Wed Oct 26, 2011 7:18 pm
I fitted a 1.3 motor and gearbox to my 1.0litre zook.
The gearbox tunnel was very tight, with my 50mm body lift.
So a hammer or widening of tunnel, or even weld in a 1.3 tunnel
may be needed.
Electric wiring is different, so transfer of wiring loom may be needed.
I have been told the body mounts dont line up, so some fabbing could be needed.
But I have never measured it up.
Body is basically same shape as a 1.3 narrow track,
so it could be feasible.
Post Posted: Wed Oct 26, 2011 7:28 pm
thanks mate ..ive got complete 1.3 chasis with 1.3 running gear no bodyand was just hoping the 1 litre shell might have been a bolt on,and used the 1 litre transfer case up the track when fitting bigger tyres. thanks again
Post Posted: Wed Oct 26, 2011 7:34 pm
Sounds like it is worth a look into.
Especially if body is a cheapy.
I started looking into fitting a 1.3 body to my 1.0,
but cost was same as just buying a 1.3.
Vehicle: 03 Jimny
Post Posted: Wed Oct 26, 2011 10:15 pm
I measure my 1.3 nt chassis with a 1l body and the mount are completely different. Front clip might be the same but body mounts are different.
Post Posted: Wed Oct 26, 2011 10:16 pm
1L body mounts are different. With a little work you can get it to fit though.
EDIT: Just to add to this, as Chrisover said, the tunnel is much narrower. The shifter hole is in a different spot, there is no accomodation for a brake booster on the firewall, the bonnet will not clear the 1.3, and I think thats about it.
Post Posted: Fri Nov 04, 2011 8:08 pm
thanks again fellas
Post Posted: Fri Nov 04, 2011 8:52 pm
I also depends on the year, my 87 1 litre has same body mounting and same tunnel as a 1300
Post Posted: Fri Nov 04, 2011 11:50 pm
I've found that if the 1.0 body uses the cone type rubber mounts, it will fit a 1.3 chassis nicely.
The early 1.0 with flat rubbers will only line up with a few 1.3 mounts.
Users browsing this forum: No registered users and 81 guests
