It is currently Mon Oct 19, 2026 11:15 pm
Vehicle: 02 jimny
Post Posted: Thu Oct 27, 2011 6:51 am
Need new rear shocks thinking of hilux rears or doetsch off low range. lengths must be 650mm- closed or 760+ open. advise or help please
LIVING LIFE ON THE EDGE, TILL YA ROLL
Post Posted: Thu Oct 27, 2011 7:00 am
Get the bilsteins. Cheap and good quality.
Vehicle: 02 jimny
Post Posted: Thu Oct 27, 2011 7:11 am
How much are the bilsteins? Does anyone know what shocks alien is running with his A frame rear
Post Posted: Thu Oct 27, 2011 7:16 am
Have a look on lowrange??
Alien aframe rear??
Post Posted: Thu Oct 27, 2011 7:20 am
A frame or leaf, doesnt matter. flex it up and measure the length shock you need.
Vehicle: 02 jimny
Post Posted: Thu Oct 27, 2011 8:20 am
Using rear shock bar measurement are as above
Post Posted: Thu Oct 27, 2011 8:40 am
http://www.lowrangeoffroad.com/index.ph ... hocks.html
Use the info they have given you to choose.
Post Posted: Thu Oct 27, 2011 8:49 am
A frame rear is a 3link/4link coil setup.
Not shocks inverted/angled/more inboard at top mount.
Vehicle: 02 jimny
Post Posted: Thu Oct 27, 2011 9:37 am
Sorry for the confusion. I think the doetsch 3000 series dt3600 will be the route i choose. does anyone on az run these. if so what do you think of them
Post Posted: Thu Oct 27, 2011 11:58 am
I used to run the 3000's on the front and they were perfectly suited to my RUF setup and took a pounding.
Post Posted: Thu Oct 27, 2011 8:48 pm
Standard rear are 283mm compressed and 544mm extended.
I always remember these lengths because they numbers just happen to be the same as the small and big chev engine cubic inches.
Users browsing this forum: Google [Bot] and 396 guests
