http://auszookers.com/forum/
Engine Removal Drama
http://auszookers.com/forum/viewtopic.php?f=5&t=27150
Author:  8ONES [ Wed Oct 26, 2011 10:52 pm ]
Post subject:  Engine Removal Drama
Hey all,
I'm trying to remove my engine at the moment and cannot remove the two upper trans/engine bolts. Lower two were easy to remove and yet the uppers I cannot even budge.
I have used releasing agent, hot water, hitting it on the end with a hammer so any other ideas or tips would be very much appreciated. I also had a mate help and between us had no success.
Regards,
Bones
Author:  christover1 [ Wed Oct 26, 2011 11:23 pm ]
Post subject:  Re: Engine Removal Drama
I'm in the middle of an engine transplant,
and one of my hard to reach bolts did same thing.
I tried all the same things.
In the end I went out and bought a cheap dremel copy,
rotary tool.
It has a long flixi extension,
and was perfect for cutting off the nut.
Damaged stud, too, but I used a bolt instead.
Good luck, it is a pain.
Author:  stockman [ Wed Oct 26, 2011 11:27 pm ]
Take the box out with it, not much more effort.
Author:  boostedbrick [ Wed Oct 26, 2011 11:29 pm ]
I ran abit of rope onto a spanner and out under the guard through the wheel arch. Helped get some more force onto the bolts.. But easy enough to just pull the whole lot at once..
Author:  8ONES [ Thu Oct 27, 2011 12:44 am ]
Thanks all, will be attempting to take out the box as well. I will let you know how I fair.
Cheers,
Bones
Author:  foolsp33d [ Thu Oct 27, 2011 12:51 am ]
x2. easiest way to do it.. will make the reinstall ALOT easier as well..
Author:  Mistaria81 [ Thu Oct 27, 2011 1:22 am ]
take both out, much easier to do and reinstall
Author:  SierraDan [ Thu Oct 27, 2011 1:36 am ]
i took engine and box out, heaps easier.
Author:  mongrelzook [ Thu Oct 27, 2011 4:11 am ]
I took head off then sat on block to get the top two bolts
Author:  stocker [ Thu Oct 27, 2011 4:31 am ]
X10... Pull engine out with box :)
Author:  christover1 [ Thu Oct 27, 2011 4:34 am ]
Now I pulled the Vit motor out,
it is clear pulling the lot out would be easier,
but in my case,
I don't have a roof thats high enough to allow that,
or a lifter capable of it.
Theres some shit hard bolts to undo,
my Sierra was easier but.
Author:  8ONES [ Thu Oct 27, 2011 8:18 pm ]
Thanks everyone,
Took the two out together, was much easier. I was able to get one of the bolts out, however, the pass side had to be grinded off as it became very rounded.....
Pics for proof :) and as I said above thanks again!! Next step will be getting the new engine back and working out how to reverse the process!!!
Cheers,
Bones
Author:  steak_knife [ Thu Oct 27, 2011 8:30 pm ]
& for future reference, it's quicker to remove the whole front clip than just the grill... :helloo:
Give's more room to... :D
Author:  2stroker [ Thu Oct 27, 2011 8:40 pm ]
And quicker still not to remove any of it just the radiator
Author:  steak_knife [ Thu Oct 27, 2011 8:44 pm ]
But look's like you know what your doing with the front clip off.... :roll:
:P
Author:  SierraDan [ Fri Oct 28, 2011 12:00 am ]
Thats what i did.
Author:  JrZook [ Fri Oct 28, 2011 12:30 am ]
SierraDan wrote:
Thats what i did.
Well done! Do you want a medal or something? :lol:
Author:  SierraDan [ Fri Oct 28, 2011 1:10 am ]
JrZook wrote:
SierraDan wrote:
Thats what i did.
Yeah mate, i'll have one of yours. :roll:
Author:  sogone [ Fri Oct 28, 2011 1:11 am ]
LOL^
