Joined: Sat Mar 24, 2007 10:30 pm Posts: 1052 Location: MORNINGTON. VIC
Posted: Tue Aug 12, 2008 9:14 pm
mine's mounted between spare wheel carrier and tailgate.
i welded 2 pieces of tube to some 6 mil flat and bolted it to the front of the carrier. works well, up hi and doesn't get in the way. i drilled a hole thru tailgate for co-ax.
haven't got time to take off spare for better pic. maybe over w/end
I had a look a mounting my mobile aerial temporarily on the spare wheel bracket but it has a slight upwards angle to it, the aerial would end up hitting the top edge of the soft top. Not sure if the hard top bracket is the same
today i made a bracket up basically the same as BAZZOOK for my soft top vitara, all i had to do was put the holes in the right place, and bend it forwards a little just above the top bolt, and that keeps the antenna away from anything and the base of the antenna flat.
thanks BAZZOOK for the idea, simple 2 make and worked well.
Users browsing this forum: Google [Bot] and 194 guests
