Page 1 of 1
[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
screwloose
Joined: Wed May 25, 2011 12:14 am Posts: 111 Location: wollongong
 Posted: Thu Nov 03, 2011 6:20 am |
Hi everyone
I have a brake issue with my Sierra.
If I leave it sitting around for a while the first time you press the pedal it goes to the floor.
After you press it once or twice it's back to normal.
There is fluid in the reservoir and no visible leaks.
Thanks
youda
Joined: Sat Oct 15, 2011 11:44 am Posts: 204 Location: Townsville
 Posted: Thu Nov 03, 2011 6:24 am |
there is a leak somewhere, probly in the wheel cylinders in your brake drums. I'd look there first
_________________ oil lights are like oven alarms, let u know its co
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Thu Nov 03, 2011 7:10 am |
It's bypassing in the master cylinder. If you're sure that there's no air in the system then replace the master cylinder
sstteevvee
Joined: Wed Apr 06, 2011 1:54 pm Posts: 134 Location: Perth
 Posted: Thu Nov 03, 2011 8:27 am |
Really need more info too, i.e what year, drums all round or rear only? If its an early model it could be something simple like the shoes need adjusting.
royce
 Posted: Thu Nov 03, 2011 8:28 am |
how long is 'sitting around for a while'?
ZookZilla96
Joined: Mon May 24, 2010 8:58 am Posts: 229 Location: Noosa Sunshine Coast
 Posted: Thu Nov 03, 2011 8:37 am |
mine is doing the same thing an i think it could have something to do with the proportioning valve because mine if i put another 150kgs over the rear the brakes are perfect!
_________________ Suncoast Exhaust & Mechanical,Noosa,QLD. All Mecha
screwloose
 Posted: Thu Nov 03, 2011 8:41 am |
It's disk front drum rear. By a while I mean an hour or so.
I bleed the brakes a couple of times to check for air getting in. If the brakes where leaking I would notice. It lives in the shed at the moment on a concrete floor. Still building
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 130 guests
