It is currently Fri Oct 09, 2026 4:22 pm
Post Posted: Sun Nov 13, 2011 9:11 am
hey guys new to the site and new to suzukis from toyotas (yes i have been converted) just requiring a bit of info on my vitara! i would like to know from peoples experience if you can fit 30' tyres on a 15x7 rim??
if so has anyone had a prob with scrubbing on full lock? running stock suspension at the mo with 2' coil spacers and need a bit more height outta the little girl, at the mo running piddley little 205/75/15 tyres that just dont cut the mustard, any info would be appreciated!!!!cheers!
Post Posted: Sun Nov 13, 2011 9:29 am
i had 235 75 15 on stock rims with only a 30mm lift in my lwb for awhile. depends on rim offset i just put them on a set of 15 by 7 with -13 yet to try them out. i think you will be ok cause with the spacers you lose a bit of travel.
Post Posted: Sun Nov 13, 2011 9:56 am
i run 29s on 15x7 -13 sunnies
i get a little bit of scrubbing at full lock on the chassis and i've given the inner guard a bit of a massage whit a hummer. when i was running 0 offset rims it didnt scrub on the guard but scrubbed more on the chassis. i have removed my swaybar.
Users browsing this forum: No registered users and 120 guests
