It is currently Sun Nov 15, 2026 11:04 am
Post new topic Reply to topic  [ 30 posts ]
Post Posted: Thu Aug 17, 2006 4:52 pm
anybody got a snorkel on an EFI vit? especially one with the battery over on the pass (why did you do this mr Suzuki you twit)
does it use the standard intake pipe fromt eh airbox to the inner guard? or do you get a new one? if so pics would be good :P
I need to find a few mm to get my dual batteries in and shrinking that pipe looks like my best option
Post Posted: Thu Aug 17, 2006 6:35 pm
Wonder if it's the same set up as RFOL GV? :wink:
he used the Toyota setup. I'll be oing that soon and you do use a different inlet pipe.
Post Posted: Thu Aug 17, 2006 6:40 pm
Not sure weather it's the same setup Rpyce. This may help
http://www.suzuki-grandvitara.nl/index.html
Click on Tech then snorkles then Airtec
Post Posted: Thu Aug 17, 2006 6:47 pm
nah vit is different setup, safari list only up to 94 which is when they moved the battery to the passenger side, it should bolt to the guard but if the intake they use is any bigger it wont fit for me or I'll have to make one that oval or something (which will then interfere with the fuse box
Post Posted: Thu Aug 17, 2006 7:48 pm
when i put the dual batteries in my vit (93 model) i had to pretty much remove the std intake to the airbox so it would fit, but i cheated and just put a pod on it...then i got a battery tray made up to fit the second battery that sat right near the firewall on the pass side...if i still had pics i would show u...but i dont
333...................im only half evil
Post Posted: Thu Aug 17, 2006 8:54 pm
royce i have asked everywhere for one over here but no one has one. The only way apparently to get one is to get one custom made.
i have pretty much given up.
Suzuki's - It's not the size,
It's how you use th
Post Posted: Thu Aug 17, 2006 10:22 pm
no problem getting one because mine isnt a wide body one
http://www.safari4x4.com.au/docs/snorkel/ss850.htm
BUT
see the little 90degree bit that goes from in the guard to the airbox, I need to find out if that is the factory bit or if its a replacement, does it come int the guard anymore than the stock bit otherwise I might be in trouble
Post Posted: Thu Aug 17, 2006 11:43 pm
all well and good but my car draws air in from the other side of the car to the one in the pic.
It's how you use th
Post Posted: Fri Aug 18, 2006 3:18 pm
i have a safari snorkel, battery is on passenger side and it is an EFI :D, what do you want to know Royce? Oh also, if you pick one up second hand, i have the template for the holes if you want.
Ric
Post Posted: Fri Aug 18, 2006 3:26 pm
I need to know if the pipe from the snorkel to the airbox is the stock one or a different one, the pipe that runs in the engine bay with the 90 degree bend in it
Post Posted: Fri Aug 18, 2006 3:33 pm
snorkel comes through side panel, then used 90 deg elbow with pipeclamp and then flexy piping for the straight. It fitted way easier than expected at first.
hope this helps
Ric
Post Posted: Fri Aug 18, 2006 3:45 pm
oooo crap I could be in trouble :oops:
could you measure from the inner guard to the outside of that bend? it looks like it comes out a bit more than the stock pipe
my battery is 335mm long and already hits on the pipe from airflow meter to throttle body so I cant shift it any further
was it hard to fit? did the template line up pretty well? I have only done a sierra one and it was crap
thanks Rick 8)
Post Posted: Fri Aug 18, 2006 4:11 pm
red lines = 120mm, my batt is only 180mm long and i have space left in my battery tray still. Obviously if you make the bend too tight you will lose airflow. template worked a treat, i kept it incase someone else fitted a snorkel to a vit oneday. hehe. it lined up really well!! i was a bit scared cutting holes in my panel though :(
another option, is you have the elbow inset inside the quarter panel because i have a small straight section coming out of the quarter panel before the bend. if you could reduce this straight section to zero, you might have a better chance and gain a good couple of cm's
Ric
Post Posted: Mon Aug 21, 2006 1:44 pm
i havent looked 'that' hard at mine, so just goin by memory, but why cant ya run the pipe inside the guard, and have it come straight out inline with the airbox and go straight into it?
Post Posted: Mon Aug 21, 2006 2:02 pm
that will be my plan b, I guess I'll have to get a look at a snorkel to see if it is short enough to have the bend inside the guard
or get one made from tube *shudder*
as long as I can use the stndard pipe from the guard to the airbox I'll be right, its only about an 80mm bend but the end that goes into the guard isnt really round so I might have to bodge something up there to attach to the snorkel
I'll have a proper look in there when I pull the plastic off to rustproof it
Post Posted: Mon Aug 21, 2006 9:45 pm
eww, no, don't make one from tube. you can cut down the moulded snorkel at the section where it goes into and through the guard, i am sure you would be able to do what antt said. i hope a homemade snorkel is your last last option!!! :)
Ric
Post Posted: Tue Sep 12, 2006 3:24 pm
Patience grasshopper. With a bit of luck there will be one available in the near future for the widetrack Vits. I'm just waiting for the manufacturer to to get the free time to take the mould of my Vit. From that point on there will be some checking and then fitment which will take place over several weeks and then it will be on the market.
Post Posted: Wed Sep 13, 2006 6:11 am
mate that will be awesome.
ill definitely be getting one when it is available
It's how you use th
Post Posted: Thu Sep 28, 2006 3:38 pm
hey cj_zuki
any updates on the widetrack vit snorkels yet?
It's how you use th
Post Posted: Thu Oct 05, 2006 3:19 am
Nope, I'm in a holding pattern waiting for his call to go and get it started. He's been pretty busy with other stuff. I will post as soon as it happens.
Post Posted: Sat Oct 07, 2006 4:39 am
How much was the SAFARI snorkel. Im in need of one. I was going to get one made from stainless but i'd prefer a molded one.
Thanks,
Chris
http://www.nbs4x4club.com
Post Posted: Mon Oct 09, 2006 11:37 pm
I picked mine up second hand CHEAP!
Vitara driver...
Post Posted: Tue Nov 21, 2006 5:09 am
cj_zuki any luck yet in getting the snorkel moulded?
It's how you use th
Post Posted: Sun Nov 26, 2006 10:20 pm
I'm booked in for the mould to be taken on the 12th of December. That's the start of the process. I'll know more then.
Post Posted: Fri Dec 01, 2006 5:56 am
cheers mate. hopefully we'll have it by winter next year
It's how you use th
Post Posted: Sun Dec 17, 2006 2:49 am
if there is a queue forming for these snorkels
to fit the J20a widetrack vitara i'm willing to wait
at the end of this queue than go the stainless
steel tube option, since we are having a drought
at the moment i'm in no real rush. cheerz
Post Posted: Fri Jan 12, 2007 6:50 pm
The mould has been taken from my Vit so it is happening. I should be in for a test fit in a few weeks time. I'll let you know when it has happened.
Post Posted: Fri Jan 12, 2007 7:38 pm
does anybody want one from me???? outdoorauto.com.au
Post Posted: Fri Jan 12, 2007 9:30 pm
Yeah but what about the oposite side? 8O
My Vit has the air box on the passangers side.. the one you posted a pic of for the 2,0L looks good but I need the mirror image..
Thanks,
Chris
Vehicle: Suzuki Grand Vitara
Post Posted: Tue Jan 16, 2007 1:10 am
My Vit is a 95 model and battery on the drivers side.
So ODA1's one be for later model's with air intake on drivers side.
cj_zuki what side are your snorkel's going on?
Users browsing this forum: Google Adsense [Bot] and 71 guests
