It is currently Sat Oct 31, 2026 8:21 am
Post Posted: Fri Nov 04, 2011 8:48 pm
Just got head back, machined and with new valves, what order and tension do head bolts go? also machine shop said i had to adjust tappets?
Is there only one way for dissy to fit? :oops:
sierra 1.3. no, no, not the vitara! thanks for help.
Vehicle: 91 Tin Top, 04 Jimny
Post Posted: Fri Nov 04, 2011 10:10 pm
I can't tell you off the top of my head, but the most common response you'll get is to have a look for a factory service manual, for the sj413.
Just have a google and see if you can find one that covers your year model, always handy, especially if you're doing a rebuild.
This should cover most of the things you need to do to your sierra/engine.
Failing that i'm sure somebody here will know. :wink:
Somewhere like this http://www.suzukiinfo.com/
Post Posted: Fri Nov 04, 2011 10:17 pm
I tryed to upload a pdf, but it didn't work... :cry:
Post Posted: Sat Nov 05, 2011 7:12 am
Normally has it somewhere on the headgasket packaging. Both order and tension.
Dizzy will fit a heaps of ways but only one will work. :wink:
TDC on cylinder 1 on the compression stroke, Rotor goes to No. 1 spark plug lead.
SS
Users browsing this forum: Google [Bot] and 463 guests
