| coily clutch with leafy gearbox, will it work http://auszookers.com/forum/viewtopic.php?f=5&t=27452 |
| Author: | experament-u2 [ Sun Nov 06, 2011 5:00 am ] |
| Post subject: | coily clutch with leafy gearbox, will it work |
Im putting a g13ba engine into my 91 leafy, before the engine goes in i plan to replace the clutch, my question is would a coily clutch fit using the leafy gearbox or can i just run a standard clutch? |
| Author: | sogone [ Sun Nov 06, 2011 5:57 am ] |
| Post subject: | Re: coily clutch with leafy gearbox, will it work |
Have you got the coily clutch already? Why not just run a leafy clutch? |
| Author: | royce [ Sun Nov 06, 2011 5:58 am ] |
use the flwheel and clutch that come from your old engine, is the easiest way to avoid any potential problems |
| Author: | experament-u2 [ Sun Nov 06, 2011 6:10 am ] |
the reason i ask is the diameter of coily and leafy clutches are different, so i didn't want to get a newy and find out it doesn't fit, looks like il just go with a standard leafy cheers |
