| Author |
Message |
JrZook
Joined: Tue Aug 08, 2006 11:30 pm Posts: 5517 Location: Holland Park
 Posted: Wed Nov 09, 2011 11:50 pm |
So
What lube do you guys use that works well and doesn't dry out and squeak and creak it's balls off only after a couple months of use?
I've been using PBR rubber grease in the past and I'm convinced that it's worse than crappy old wheel bearing grease! Longest I've had the PBR in without noise was a couple of months, shortest was a couple of weeks!
It turns into the most sickest crap ever, almost as if it's melting the rubber bushes!
I'm currently trying some Shell Nautalus marine waterproof grease too see how long that lasts. So far a week and counting!
Any suggestions?
Note: My vehicle is not a POS nor does it look like a POS hence cranking up the tunes to mask the sounds of a POS is not an option
_________________ Lil Foot!
http://tiny.cc/gtsw1
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9716 Location: NSW
 Posted: Wed Nov 09, 2011 11:56 pm |
What kind of bushes are you running?
I always used to run mine dry. No creaks, no worries. They were probably that worn that they never had a good surface to squeak on
Do you have grease nipples machined into the shackles?
royce
 Posted: Thu Nov 10, 2011 12:06 am |
you only grease rubber for installation, its meant to bind against the surfaces and twist to provide is bushing function, hence why I always laugh at you all thinking they are better
youll notice your average tyre (also rubber) isnt really too slippery day to day
boostedbrick
Joined: Tue Jun 29, 2010 7:44 am Posts: 2003 Location: Brisbane
Vehicle: 2018 DMAX
 Posted: Thu Nov 10, 2011 12:13 am |
I use bearing grease when ever I put mine together.. Seems to last for quite a few months..
Don't know if it actually helps the bushes but seems to make it allot easier to replace them down the track. Stops the crush tubes rusting and makes removing the bolts easier.
Either way, some types of grease will be corrosive to rubber so careful what you use if you do.
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Thu Nov 10, 2011 12:50 am |
Wet Stuff Gold
_________________ Shep is a closet jimny lover!!!!
JrZook
 Posted: Thu Nov 10, 2011 1:03 am |
royce wrote: you only grease rubber for installation, its meant to bind against the surfaces and twist to provide is bushing function, hence why I always laugh at you all thinking they are better
That is how the bush is men't to work tho I doubt that any captive bush would twist enough to give near 90* shackle movement.
These are genuine Suzuki rubber spring bushes. 2 years so far out of them and counting. Know of any poly bushes that are a nice tight fit and are as soft as the rubber ones and last?
No grease nipples in the shackles tho I have ground a flat in them to try and retain lube.
royce
 Posted: Thu Nov 10, 2011 1:10 am |
Whats wrong with urethane?
you can have it as soft as you want, self lubricating, most oil and grease wont worry it, deforms more
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Thu Nov 10, 2011 6:40 am |
not that I am a rubber bush fan, but maybe try that dry lube stick stuff.
its sort of like sticky wax.
I really dont think rubber bushes are supposed to be lube though
missmyljdaze
Joined: Tue Jul 05, 2011 7:16 am Posts: 2323 Location: perth
 Posted: Thu Nov 10, 2011 6:52 am |
[quote="Know of any poly bushes that are a nice tight fit and are as soft as the rubber ones and last?[/quote]
those nice, soft rubber bushes- when installed properly- are usually under compression and practically rock hard.
lube for rubber bushes is for installation only.
rubber is supposed to wear out, (something has to wear out somewhere!) like Royce said- urethane lasts longer, deforms better, oil and grease wont rot it away and is possible to get in different grades.
stephen.
stocker
Joined: Wed Dec 08, 2010 7:16 am Posts: 941 Location: Shidoni!
 Posted: Thu Nov 10, 2011 7:37 am |
i use molygrease on my urethane bushes
_________________ Stocker
missmyljdaze
 Posted: Thu Nov 10, 2011 8:46 am |
stocker wrote: i use molygrease on my urethane bushes
which (iirc) is the stuff that is supplied with the bushes.
banga
Joined: Tue Nov 17, 2009 10:30 pm Posts: 668 Location: sunshine coast
 Posted: Thu Nov 10, 2011 6:12 pm |
we use graphite grease at work on or urethane bushes and all or shockie bolts and all or camber bolts for the caravans it is friggin awesome stuff
_________________ lseries 2" body lift king springs 27" boots and a
matfan
Joined: Sat May 29, 2010 4:27 pm Posts: 935 Location: Paraguay
Vehicle: WT Tinny, NT lwb, 1L lwb
 Posted: Fri Nov 11, 2011 2:02 am |
toothpaste works well for installation, plus it keeps your bushes cavity free!
_________________ JrZook - Mine only hangs 2.5".
