It is currently Tue Sep 22, 2026 10:48 am
Vehicle: Yellow Ute
Post Posted: Fri Nov 11, 2011 10:05 pm
G'day.
How is the back drive shaft meant to be aligned. I was always told it was like this )--------( but even after putting new unis in I am still getting some funky vibes.
Thanks
Post Posted: Fri Nov 11, 2011 10:26 pm
Did you feel for movement in the jack shaft? Or tyres not balanced, or movement in the diff flange? Or tcase for that matter?
Vehicle: Yellow Ute
Post Posted: Fri Nov 11, 2011 10:36 pm
Changed the uni's in the jack shaft it is all good.
I assume you just wobble the diff flange? It was solid. Same with tcase flanges.
Tyres might be it. When they were put on the fella said it took a fair bit of weight to balance.
Post Posted: Fri Nov 11, 2011 10:39 pm
This thread on Zuwharrie is a how to phase the driveshaft properly.
http://bbs.zuwharrie.com/content/topic,16725.15.html
Post Posted: Sat Nov 12, 2011 12:00 am
The driveshafts with the splines have a dot to line up :)
Uni's have to be a mirror image.
Users browsing this forum: No registered users and 237 guests
