| will 30" tyres fit on a 15x7 sunraysia with 2' spring spacer http://auszookers.com/forum/viewtopic.php?f=5&t=27648 |
| Author: | trenno81 [ Sun Nov 13, 2011 9:11 am ] |
| Post subject: | will 30" tyres fit on a 15x7 sunraysia with 2' spring spacer |
hey guys new to the site and new to suzukis from toyotas (yes i have been converted) just requiring a bit of info on my vitara! i would like to know from peoples experience if you can fit 30' tyres on a 15x7 rim?? if so has anyone had a prob with scrubbing on full lock? running stock suspension at the mo with 2' coil spacers and need a bit more height outta the little girl, at the mo running piddley little 205/75/15 tyres that just dont cut the mustard, any info would be appreciated!!!!cheers! |
| Author: | banga [ Sun Nov 13, 2011 9:29 am ] |
| Post subject: | Re: will 30" tyres fit on a 15x7 sunraysia with 2' spring spacer |
i had 235 75 15 on stock rims with only a 30mm lift in my lwb for awhile. depends on rim offset i just put them on a set of 15 by 7 with -13 yet to try them out. i think you will be ok cause with the spacers you lose a bit of travel. |
| Author: | alexvitara [ Sun Nov 13, 2011 9:56 am ] |
i run 29s on 15x7 -13 sunnies i get a little bit of scrubbing at full lock on the chassis and i've given the inner guard a bit of a massage whit a hummer. when i was running 0 offset rims it didnt scrub on the guard but scrubbed more on the chassis. i have removed my swaybar. |
