| NONZUKQuestion: Ifs Hilux box, What pump? http://auszookers.com/forum/viewtopic.php?f=5&t=27659 |
| Author: | BlueSuzy [ Mon Nov 14, 2011 1:09 am ] |
| Post subject: | NONZUKQuestion: Ifs Hilux box, What pump? |
Hi all. Im currently converting my Sierra to a lux ifs box, (lux diffs etcetc) I am wondering what pumps everyone is using? I think i need a Toyota pump with Multiv pulley. Is there such a thing? Will make engineering easier as then its all Toyota.. I also have a AU Falcon pump,mulitv, well known for their leaks, and are common, But will there be enough pressure for the lux box? I have seen one run with a cruiser box, but still unsure. But what have others run? Other info: G16b efi Suz motor, Lux diffs, 35"s. Minimal offset rims Thanks for any help. |
| Author: | royce [ Mon Nov 14, 2011 1:13 am ] |
| Post subject: | Re: NONZUKQuestion: Ifs Hilux box, What pump? |
lots of buggy guys up here run modded falcon pumps and seem to do ok, they are the older type with the tank built in though |
| Author: | Gwagensteve [ Mon Nov 14, 2011 1:18 am ] |
The polyvee pullied falcon pumps we've played with have been nothing but trouble - belt slippage has been the biggest issue. I think both guys that set up on them down here have gone back to vitara. (that's with a vitara box) Steve. |
| Author: | BlueSuzy [ Mon Nov 14, 2011 1:20 am ] |
Mine has the tank built in, Tear drop shape. From memory its off an Au? It has a 6pk pulley but will only be running a 4pk belt. A Jim ac compressor will also be on the same belt with a seperate idler/tensioner |
| Author: | want33s [ Mon Nov 14, 2011 5:53 am ] |
Falcon pump will run a lux box no problems. Even better if you mod it for increased flow/pressure. |
| Author: | BlueSuzy [ Mon Nov 14, 2011 7:17 am ] |
Cool. I will mount it and test it then. Mod if needed later. Thanks guys |
