It is currently Fri Oct 16, 2026 5:04 pm
Post Posted: Tue Nov 15, 2011 6:20 am
As the title states can new bearings be re pressed off an axle and pressed back on to be re used?
I think my bearings are on back to front as my drum is making contact with the backing plate..
Post Posted: Tue Nov 15, 2011 6:33 am
Have you replaced your wheel bearings at the same time?
I had the same issue when I used NT wheel bearings on WT. 5mm difference.
SS
Post Posted: Tue Nov 15, 2011 6:47 am
Yes I replaced my wheel bearings...
I hope that isnt my problem and I am going to be fuming if that is the case. I told them what blood make and modle my car is.
Post Posted: Tue Nov 15, 2011 7:58 am
Yep I told them the make and year too. :cry:
My story.
http://www.auszookers.com/index.php?nam ... ght=siezed
SS
Vehicle: Yamaha scooter, 50cc
Post Posted: Tue Nov 15, 2011 8:16 am
I got the wrong size brake shoes, there were 2 different sizes in the WT's, the change over was about 93, but some of the later models still had the old size, must have been using up left over parts.
Anyway, I've got a brand new set of shoes here to suit the later model drums if anyone wants em, they can have em for a long neck.
Post Posted: Tue Nov 15, 2011 9:35 am
How will that stop my problem nato78?
How much will a mechanic charge to do wheel bearings or just fix my problem?
Can bearings be pressed off and reused again?
I am seriously over it, its been 8 days going, something that should of took 1 day aswell
Post Posted: Tue Nov 15, 2011 9:29 pm
New Questions, edit at the top!
Post Posted: Tue Nov 15, 2011 10:18 pm
I'm not sure you'd be able to get the locking collar off the axle without grinding it off.
If you can I can't see why you can't use the bearings as long as they aren't damaged in the removal process.
Post Posted: Wed Nov 16, 2011 4:45 am
Not worth the hassle for the price of replacement....
Good lesson for ya mate.... :helloo:
Post Posted: Wed Nov 16, 2011 11:12 am
its ok ive done a mates axles thinking they were mine and left the backing plates off :oops:
josh AKA Bazook
Post Posted: Fri Nov 18, 2011 6:52 am
Dunno why I wrote that there?? Must have been having a bit of a brain fart, sorry :oops:
Post Posted: Fri Nov 18, 2011 7:08 am
yep but you would still be the dickhead that didn't put them side by side first and check before fitting :wink:
Post Posted: Fri Nov 18, 2011 7:09 am
he changed the title of the thread after you posted that, it was originally about rear brake shoes.
Users browsing this forum: Google [Bot] and 243 guests
