http://auszookers.com/forum/
Wheel nuts
http://auszookers.com/forum/viewtopic.php?f=5&t=27811
Author:  RUN.10W [ Fri Nov 18, 2011 10:48 pm ]
Post subject:  Wheel nuts
I have sunraisers (check spelling :]) and I'm wondering the best wheel nuts for them? I had mags on there when I purchased the car so the wheel nuts are lug chrome nuts they work but I just thought there may be a better option as sometimes they don't seem to sit against the resest bit of the wheel the best nor hold tight all that good. Thanks guys.
Author:  SierraDan [ Fri Nov 18, 2011 10:55 pm ]
Post subject:  Re: Wheel nuts
They need to fit In the countersunk part of the rim.
Author:  RUN.10W [ Sat Nov 19, 2011 12:07 am ]
Yes I know that but the ones I have fit in but seem slightly sloppy so was wondering if there are any other sorts, the wheel shops said the ones I have are it.
Author:  fordem [ Sat Nov 19, 2011 12:52 am ]
Look at the recess in the wheelwhere the nut fits - does it have a flat seat or a tapered seat? Now look at the nut - does it have a matching flat or tapered base?
Wheels with a tapered bottom or countersunk recess are "lug centric" and depend on the lug nuts having a matching taper to center the wheel - the matching taper gives the impression that the nuts are a close fit.
Wheels with a flat bottomed recess are "hub centric" and depend on a close fit between the hub & the center bore to center the wheel - hub centric wheels use a nut with a shank and a captive washer to secure the wheel - the shank will be a sloppy fit in the hole to allow the wheel to center on the center bore.
Author:  Gwagensteve [ Sun Nov 20, 2011 1:12 am ]
Sounds like you need stock sierra wheel nuts which will have a 60 degree taper.
Author:  buzbox [ Sun Nov 20, 2011 3:22 am ]
Red ones :)
like these:
M12X1.25
http://www.ebay.com/itm/X20-LOCKING-LUG ... 27c073d332
But you really will need red valve caps too.
