It is currently Mon Oct 26, 2026 6:50 am
Post Posted: Sun Nov 20, 2011 8:33 pm
I have bee looking around my motor a bit lately to try and find out why it is so f**king gutless so today I pulled off the belt cover to have a look and this is what I found:
[img][IMG]http://img705.imageshack.us/img705/7359/suzukis.jpg[/img][/img]
The crank is positioned at No1 TDC. Isn't the mark supposed to be at the top? It is currently at the bottom.
Post Posted: Sun Nov 20, 2011 8:51 pm
Are you sure No.1 isn't on the firing stroke? It wouldn't run like that.
Make sure by getting some hose and blowing into No.1 plug hole. There should be no air escaping.
Vehicle: 85 hightop drover
Post Posted: Sun Nov 20, 2011 8:53 pm
The crank spins twice, for every one spin
Of the cam. So you have the no1 at the top
Of the exhaust stroke. But you need it at the
Top of the firing stoke. So as is just rotate the
Motor (one full spin of the crank and 1/2 of the
Cam) and then the timing marks should line up
16valve efi hightop drover
Post Posted: Mon Nov 21, 2011 1:43 am
But the rotor inside the distributor is pointing to No.1 hence it should be at the top of the firing stroke?
Post Posted: Mon Nov 21, 2011 1:55 am
1.3 timing is done with marks pointing at each other,
crank up, cam gear down... I think I remember.
My Vit isn't, that had me confused fer a bit,
its both marks up.
Post Posted: Mon Nov 21, 2011 1:56 am
anyone who has read even one timing belt thread knows they all time to no4 firing
Post Posted: Mon Nov 21, 2011 1:57 am
Always did my 1.3 on no 1, marks pointing at each other.
Probably same thing?
Post Posted: Mon Nov 21, 2011 4:00 am
I stand corrected haha ive done 3 timing belts
On G motors I just assumed it was no1.
Post Posted: Mon Nov 21, 2011 4:18 am
It's probably just the shitty fuel you get over there :lol:
Have you checked advances? What's the carby like?
Post Posted: Mon Nov 21, 2011 4:49 am
Last time I checked the mechanical advance it only went to about 20 and as for the carby the secondary doesn't work but I dodgied it up with wire so that it does :lol: I think I might need bigger jets in the carby too as I have extractors and a 2" and a k&n filter. What would you recommend?
Post Posted: Mon Nov 21, 2011 8:26 am
i just did i timing belt on a g13ba (front wheel drive 1.3 swift) and when i pulled the cover off, both marks where up, it went on that way and it fired straight away. ran awesome.
Post Posted: Mon Nov 21, 2011 11:37 pm
Yep
Lil Foot!
http://tiny.cc/gtsw1
Users browsing this forum: Google [Bot] and 221 guests
