| Factory options, adding to them? http://auszookers.com/forum/viewtopic.php?f=5&t=27878 |
| Author: | jonno_racing [ Mon Nov 21, 2011 12:16 am ] |
| Post subject: | Factory options, adding to them? |
ok so i have been shopping a fair bit for jimnys atm and something i want is Cruse Control, however i have only scene one jim with this! is there any relatively easy way to add things such as cc to a jim without it, as in a plug and play deal?? and can you buy the factory parts?? im guessing jim would need a module and the stork with switches on it? Phil |
| Author: | SierraDan [ Mon Nov 21, 2011 12:20 am ] |
| Post subject: | Re: Factory options, adding to them? |
Take your time when looking and one with what you want and cruise control will come by. |
| Author: | BlueSuzy [ Mon Nov 21, 2011 12:21 am ] |
Get an aftermarket cruise. |
| Author: | jonno_racing [ Mon Nov 21, 2011 2:16 am ] |
thats pretty much the plan dan. but id like to know if it came down to it and i found good jim cheep that i can just get the factory bits plug it in and call it a good thing. |
| Author: | oozuk [ Mon Nov 21, 2011 4:28 am ] |
factory cruse will always work better and integrate better than an after market one. I opted for an after market cruse control system back when i bought my GV new many years ago and it was not a cheap one, i installed it correctly my self and it was a load of shit !! the switch gear was flimsy and fell apart and after long periods of using the cruse control and when a steeper than normal hill was met it would shut off shop around and get one with the factory options that you want, would like to think the later M series jimny's would have a better chance of having cruse control. |
| Author: | BlueSuzy [ Mon Nov 21, 2011 5:33 am ] |
My outback has cutout a few times while towing to qld..not heavy load either.. |
| Author: | jonno_racing [ Mon Nov 21, 2011 6:27 am ] |
does any one know if the componants for the factory curse plug in to the standard wiring loom?? as in do they run the same loom with stuff just not plugged in? |
| Author: | oozuk [ Mon Nov 21, 2011 6:35 am ] |
jonno_racing wrote: does any one know if the componants for the factory curse plug in to the standard wiring loom?? as in do they run the same loom with stuff just not plugged in?
google is your friend, pretty much every cruse control unit in repco, autobarn is a one unit fit's all brands ect they use the VSS signal for reference or the really cheap ones use a magnet tip tied to the tailshaft with a dodgy bracket with the pickup, then supply w universal bracket to mount on the throttle for the cruse control cable and then you usually need to get a vacuum supply for it. |
