It is currently Wed Oct 28, 2026 7:27 am
Vehicle: '91 Sierra, Fluffy Dice.
Post Posted: Tue Nov 22, 2011 4:26 am
So basically as the title says, I'm trying to override/ remove the black immobiliser out of my Sierra! I'm sick of the fucking thing so any help as how to get rid of it will be greatly appriciated!
If at first you don't succeed, get a bigger hammer
Post Posted: Tue Nov 22, 2011 4:55 am
you can by-pass it real easily. i have the same one! ill go have a look at how i can descirbe how to do it later, but with mine its a matter if unplugging two wires and joining them together!
THINKING BEFORE POSTING!!!
Post Posted: Tue Nov 22, 2011 5:05 am
Yeah I figured it out! All I did was open the motherboard, and connect the spade plugs to each other.
but now I have another problem, when I turn the key the fan/ alternator only goes 5th of a turn then stops and makes a whining noise
Vehicle: 4wd
Post Posted: Tue Nov 22, 2011 5:33 am
Does the motor run?
Watch out or you'll get sued.
Post Posted: Tue Nov 22, 2011 5:41 am
Well it DID untill this popped up! She ran perfectly fine before it just stopped but it's slowly starting to crank for longer if I wait a while between cranks
Post Posted: Tue Nov 22, 2011 5:43 am
flat battery?
Post Posted: Tue Nov 22, 2011 5:47 am
Yeah that's what I was thinking aye, got the charger on it now but last time I had a dead battery it didn't act like this but maybe it's because there's just 11 volts atm
Users browsing this forum: Google [Bot] and 280 guests
