| What's the easy way http://auszookers.com/forum/viewtopic.php?f=5&t=27932 |
| Author: | Daves4wd [ Tue Nov 22, 2011 6:08 am ] |
| Post subject: | What's the easy way |
Eu guys and girls what's the easiest way to get the fly wheel bolts off?? Cheers also might add I can't get my hands on a rattle gun till tomorrow |
| Author: | ajsr [ Tue Nov 22, 2011 6:17 am ] |
| Post subject: | Re: What's the easy way |
use some muscles you limp dick they are not that tight |
| Author: | reeceh [ Tue Nov 22, 2011 6:19 am ] |
Jam a big screwdriver in the teeth to something else or even in the front pullys. Do it's wedged then use a breaker bar and try do a short hard burst instead of a constant pull. U wanna crack em loose so to speak! |
| Author: | christover1 [ Tue Nov 22, 2011 6:20 am ] |
Is in or out of car? You need a way to stop motor turning. Spanner on crank pulley is one way. And a decent socket with a very long bar. Or a pole to slip over a short bar. Watch ya knuckles, fly wheel teeth bite. |
| Author: | christover1 [ Tue Nov 22, 2011 6:22 am ] |
PS, on odd occassions, crank pulley comes loose instead |
| Author: | buzbox [ Tue Nov 22, 2011 6:38 am ] |
Easiest way, air impact wrench. Otherwise use screw driver to jam it in the teeth and use a breaker bar. |
| Author: | TZAR [ Tue Nov 22, 2011 6:47 am ] |
tyre lever jammed though starter motor hole and then undo. rough way is to undo spark plug get on firing stroke (so valves are shut) make sure piston is as low as it will go and feed rope into the cylinder until you cant squeeze anymore in then use a breaker bar and kick it. or you could use a square edged big screw driver or bit of flat steel and follow noob cad pic. Just loosen bolts using this method IE 1 and 2 then turn a bit anddo the next two. Best if you can just wedge it against chassis rail ground and give a kick |
| Author: | Daves4wd [ Tue Nov 22, 2011 6:55 am ] |
reeceh wrote: Jam a big screwdriver in the teeth to something else or even in the front pullys. Do it's wedged then use a breaker bar and try do a short hard burst instead of a constant pull. U wanna crack em loose so to speak!
Thanks for that buddy all good now to do The one that's a bare block hahaha |
| Author: | Daves4wd [ Tue Nov 22, 2011 6:58 am ] |
The next one I can't damage as I need the flywheel the first one is in good nick don't need it awesome as thanks for the help guys much appreciated Also my knuckels are in goOd nick no damage |
| Author: | bazook [ Tue Nov 22, 2011 7:02 am ] |
air gun is the easy way |
| Author: | pyrohamish [ Tue Nov 22, 2011 9:07 am ] |
without a impact wrench get a decent socket and breaker bar with a hammer and block of wood |
