It is currently Sat Nov 14, 2026 7:27 am
Vehicle: 97 Coily, Winch Comp Vitara
Post Posted: Wed Nov 23, 2011 6:28 am
I'm going to be putting a G16B into my 1997 Sierra. Has a 2 inch body lift at the moment. I will be using the BenT adaptor kit. My question is will I need to modify the sump on the G16B at all for clearance?
Post Posted: Wed Nov 23, 2011 6:31 am
That depends on axle position and bumpstop location. It's best to swap in the G13 Sump and oil pickup. Most likely the G16 sump will foul.
Post Posted: Wed Nov 23, 2011 6:50 am
Stock bump stops. Are there many people who have put this motor into a coily?
Post Posted: Wed Nov 23, 2011 7:06 am
Talk to toobzook he's got on in his
Vehicle: 02 jimny
Post Posted: Wed Nov 23, 2011 7:11 am
On my leafy im still running 1.6 sump. been in 8months
LIVING LIFE ON THE EDGE, TILL YA ROLL
Vehicle: 4wd
Post Posted: Wed Nov 23, 2011 7:16 am
It would also depend on the 16b motor.
Watch out or you'll get sued.
Vehicle: 85 SJ413
Post Posted: Wed Nov 23, 2011 7:42 am
Steve is correct, it is best to swap the sump with the 1300. It depends how much lift and how much bump-stop spacing you have done.
The diff will touch the sump in a leafy when the suspension compresses to the stock bump-stops. It may be slightly different in a coily, but I doubt by much.
I have installed a 1600 in a Coily with the stock 1600 sump, but it had 4 " of lift, and most importantly, 2" of bump-stop spacing.
Ben
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Post Posted: Wed Nov 23, 2011 7:48 am
i put a photo on here somewhere a few years ago of a 8v vitara motor in a leaf sierra.
the diff was on the bumpstops(20mm extended) and there was at least 60mm
vertical clearance and 25mm sideways clearance between the sump and diff.
Users browsing this forum: No registered users and 78 guests
