It is currently Mon Oct 12, 2026 12:34 pm
Post Posted: Wed Nov 23, 2011 6:11 am
http://www.ebay.com.au/itm/SUZUKI-Sierr ... 500wt_1228
hey guys can anyone tell by looking at this if its a ltr transfer case?
i pm'ed the guy asking if its got the switch for the 4wd light and he said he doesn't know????
also does it look like its got the WT franges installed?
also hes got these modified drivesafts for sale. Do u need them to install the TC?
If this is the right set up i will probably buy it
Post Posted: Wed Nov 23, 2011 6:12 am
No light.
Vehicle: 2018 DMAX
Post Posted: Wed Nov 23, 2011 7:09 am
No light, which is why he has the drive shafts to suit. Drive shafts are gonna need to be some half assed mix match compilation of stockman and sierra bits.. Will work but you will have different size unis to play with...
Post Posted: Wed Nov 23, 2011 12:44 pm
There is nothing half assed about it, it is a simple and effective solution, only difference is with the cups on the uni having a different circlip position. Did you know that a non switch 1litre transfer is lower geared than a switched 1litre case.
Post Posted: Wed Nov 23, 2011 6:33 pm
So its pretty much bolt in ? Do u think he's asking too much them? Bid starting at $125 for the transfer case and 125 for the driveshafts. seems like its just a better option to find a switched case
Post Posted: Wed Nov 23, 2011 6:37 pm
double that and you have almost got 6.5's delivered,
i am well and truly on the 6.5 bandwagon now haha
Post Posted: Wed Nov 23, 2011 11:35 pm
Yeah I see where you are coming from, if the bidding goes nowhere it is still $250. I have been selling switch ones for $200 when I get them.
Don't forget to factor in that if you do buy a switch one you still have to take the flanges off your transfer to make it work so your transfer cannot be sold as a complete unit.
Users browsing this forum: No registered users and 224 guests
