It is currently Sat Oct 10, 2026 4:20 pm
Post Posted: Sun Aug 14, 2011 12:10 pm
whats the thing called that reads the error codes on efi motors and would it be the
same tool for a 91 16v g16 vitara and a current model 2.4 gv.
also where can i buy one?
Vehicle: Sj70 tintop
Post Posted: Sun Aug 14, 2011 12:15 pm
its called a geniric scan tool..... :lol:
I think snap-on does one, you buy the unit then buy keys for each different vehicle
:lol:
Sj70 tintop
Post Posted: Sun Aug 14, 2011 12:18 pm
it's called a Generic Scan Tool I'm not sure if it is compatible possible you could just get different plugs but not sure.
Vehicle: Yamaha scooter, 50cc
Post Posted: Sun Aug 14, 2011 12:29 pm
Post Posted: Sun Aug 14, 2011 12:44 pm
ahaha, 3 responses with the same thing. so why not add another.
im pretty sure snap-on make one, its called a Scan tool. you need a different key for each vehicle tho. you just "scan" the tool over the engine, as close to the rocker cover as possible and it read all the failures happening inside. it must have x-ray vision or something to see whats going on. :D :D :roll:
Vehicle: '96 LWB trayback
Post Posted: Sun Aug 14, 2011 12:45 pm
If the vehicle in questions uses OBD-II (on board diagnostics port) you can pick up a generic scan tool from ebay for under $100.
The snap-on one recommended above is about $10k with all of the keys for full vehicle coverage.
Post Posted: Sun Aug 14, 2011 1:23 pm
Snapon do one for about $2500 that will do most stuff its called an ethos
Post Posted: Sun Aug 14, 2011 6:32 pm
I use the one sold by Repco. $150. Talks to maybe 60% of vehicles? It will usually spit out the code but can't tell you what it means, google will fix that tho
Post Posted: Sun Aug 14, 2011 7:58 pm
I have one of these. Bloody good.
The ScanGauge II can check for Diagnostic Trouble Codes (DTCs) and if found, can display how many there are and the Trouble Codes themselves. Using the internet or repair manuals, these can be translated to the failed component and repairs can be made.
Data captured when the Trouble Code was set can be recalled to help troubleshoot the problems (was the temperature hot or cold, speed high or low, etc.). The ScanGauge II can be used to clear the trouble codes and data which will turn off the warning (Check Engine, Service Engine soon, etc.) lamp.
Does lots of other cool stuff as well.
http://www.scangauge.com.au/products/
Post Posted: Sun Aug 14, 2011 8:16 pm
though current model GV is CAN BUS so a lot of basic generic stuff may struggle, without the right protocols
Post Posted: Sun Aug 14, 2011 8:48 pm
Dear Shep
Ignore this thread, unless Stekky or Rhinoman post
the 1.6 there is no tool needed, you just short 2 pins on s plug and the check engine light flashes to tell you whats going on
That later one wont be a problem while you own it :wink:
A lot of Suzuki's AREN'T OBDII so the generic stuff doesnt work
Post Posted: Sun Aug 14, 2011 8:53 pm
Well I'll just crawl back into my hole again.
Post Posted: Sun Aug 14, 2011 9:04 pm
Hey Royce, does this include the twin cam Jimny's?? I got supplied one of these http://www.rennacs.com/products.php#bluetooth through work and I can't get it to communicate with the Jim, but has no problems with most other cars.
And dont come out without asking this time!
Post Posted: Sun Aug 14, 2011 9:55 pm
I've seen some pretty Inventive two pin "code pulling tools".
Eg. Coathangers bent to shape like Ataris masterpeice. I'm sure he will be able to post a pick for you :)
Post Posted: Sun Aug 14, 2011 10:26 pm
It could do, I dont know which (if any) Suzuki are real OBDII
I have this http://www.auszookers.com/index.php?nam ... diagnostic
Maybe try that software with your unit? but then I think the pinouts differ too from memory
Post Posted: Mon Aug 15, 2011 1:10 pm
Yep as above (as in normal scan tools dont work), All you need is a bit of wire! I followed the guide on rhinopower.org Of course you need the diagnostics plug and check engine light wired up but. I also bought a cable of rhinopower to use with his free software.
Post Posted: Mon Aug 15, 2011 1:17 pm
thanks for the info that is right and you lot that wanted me to give the
snapon man a few grand for a tool that i couldn't use can get a big dog up yas.
Post Posted: Mon Aug 15, 2011 1:25 pm
Shep, send me $1,247.33+ GST (gus' service tax) & i will supply you with a custom made error code reader
Attached is a word document explaining how to use the hi tech device. :wink:
Post Posted: Mon Aug 15, 2011 10:03 pm
What does OBDII mean? When my integra was showing an error code I got my mechanic to diagnose it, his flash snap setup was $24,000.. Looks like he got a bad deal!!
Post Posted: Mon Aug 15, 2011 10:51 pm
OBDII = On Board Diagnostics. It's becoming standard across most vehicles now. II just means version 2.
Post Posted: Tue Aug 16, 2011 4:39 am
:lol:
^^ this was meant to be the fail whale... but it didn't work.
Vehicle: 02 GV
Post Posted: Tue Aug 16, 2011 6:07 am
I have a cheap ebay bluetooth adapter for $17 and "torque" android app(free version), unfortuatly 02 gv was not OBDII compliant in australia.
Works perfect on alot of cars though.
Post Posted: Fri Aug 19, 2011 10:24 pm
I will try this when I get some time. I don't thin it'll work but you never know
Vehicle: 2001 Jimny M13A
Post Posted: Sun Aug 21, 2011 11:41 pm
This is as far as I've got with understanding my little bus!! :blink:
Post Posted: Tue Aug 23, 2011 11:29 am
"OBD2" is actually a US standard* mandated in 1996, that standard didn't include KWP2000 or CAN but has since been superceded. The European standard which did include KWP2000 is often referred to as EOBD but despite difference in the data communications and hardware all the protocols transmiut the same basic data.
From 2006 Australia adopted Euro 4 regulations which means that any generic scan tool that covers ISO9141-2 and KWP2000 (ISO14230) should work but many generic toools fail to connect properly to KWP2000 and need to have ISO14230 (Fast init) manually selected. I'm not sure when CANbus was adopted in Aus but again a generic tool should work.
Prior to 2006 its a bit fuzzy, some vehicles have SDL, the original Suzuki proprietary format, some use ISO9141-2 an OBD2 standard and others use a Suzuki proprietary format based on KWP2000 called SDL-KWP.
I have been working on SDL-KWP but I haven't been able to get my hands on an ECU to test.
Incidentally if you're using CANBus with a laptop interface always use the internal battery only - plugging the laptop into the mains is a good way to smoke the ECU.
* In actuality its a collection of around 12 standards that includes, IIRC, five different protocols.
2000 Suzuki Vitara 1.6 8V
1986 Suzuki SJ413K
Post Posted: Thu Nov 24, 2011 4:27 am
Hey I just tried the diagnostic on my g16B.
engine light flash 3 times paused and flashed 4 times.
Can anyone tell me what error this is??
Post Posted: Thu Nov 24, 2011 4:30 am
Error code 34?
I want my old sig back :(
Post Posted: Thu Nov 24, 2011 4:32 am
there is a pdf attached to my earlier post, download it & find the code on the list. :roll:
http://kick-fix.com/ECU/DTC-errors/DTC-jtgh.html
Google is your friend.. This is for US sidekicks, may be the same?
34: MAF (16valve only) Air Flow Sensor Circuit ,too low current. , lower than 0.65mA detected
EDIT: This aligns with atari's document too...
Users browsing this forum: No registered users and 324 guests
