It is currently Fri Oct 09, 2026 7:13 am
Post new topic Reply to topic  [ 52 posts ]  Go to page 1, 2  Next
Vehicle: 02 jimny
Post Posted: Thu Nov 24, 2011 7:47 am
Hey guys this arvo i measured up for new rear shocks and i had it flexed up and noticed i had plenty of gap between tyre and guard. And thought since ill making the right distance so the shock wont bottom out whats stopping me from cutting 20mm off the rear bump stops to gain a bit of up travel. I have a 2inch Body Lift and rear leafs are only got 3 leafs per pack and standard rear shackles.
Thanks
Matt.
LIVING LIFE ON THE EDGE, TILL YA ROLL
Post Posted: Thu Nov 24, 2011 8:05 am
The extra up-travel will most likely destroy the leafs
Lil Foot!
http://tiny.cc/gtsw1
Vehicle: 02 jimny
Post Posted: Thu Nov 24, 2011 8:20 am
Is that cause they're are going more flat? would it make the shackles inverted
Vehicle: ute
Post Posted: Thu Nov 24, 2011 8:25 am
I lifted mine up on a forklift to measure shock length noticed the bumpstop limiting travel, removed it lifted it again and bent the spring now its sits nice and low in that corner, sweet!
Vehicle: 02 jimny
Post Posted: Thu Nov 24, 2011 8:29 am
Hmmm. think ill give it a miss then.
Vehicle: 02 jimny
Post Posted: Thu Nov 24, 2011 8:32 am
There's gotta be a easy way to get rear travel. will cutting the rear hanger off and moving it forward with longer shackles work. would it be the same effect as longer springs
Post Posted: Thu Nov 24, 2011 8:37 am
Probably closer to a dropshackle effect.
edit: without "bang im fully open"
Post Posted: Thu Nov 24, 2011 8:40 am
It's not the same as longer springs, but it does work. It's really the only way to get more droop other than a longer spring or 3/4 elliptic.
Bear in mind though that longer shackles are illegal and you won't be able to put standard shackles back on once the hanger has been moved.
Vehicle: ute
Post Posted: Thu Nov 24, 2011 8:43 am
you need to be careful longer skackles like longer springs or they invert and get messy, longer softer springs flex good, but not great. the rear is hard too much flex and you car gets all unbalanced and ugly in the steep stuff, lockers negate the need for for heaps of flex my last car had average flex but front and rear lockers and it idled over any thing
Vehicle: 02 jimny
Post Posted: Thu Nov 24, 2011 8:46 am
Is there a diy or how to 3/4 elliptical. had a search but manly just people mentioning it
Post Posted: Thu Nov 24, 2011 9:00 am
i trimmed a fair bit off the bumpstops of my challenger and it allowed a fair bit more up travel
did 130000km on the springs and they still worked fine.
Vehicle: ute
Post Posted: Thu Nov 24, 2011 9:08 am
If youre cool going illegal the sky's the limit my 3/4 eliptical gives good droop
its simple to dummy up cut and old spring in half, fit the eye end in the top of the shackle clamp the cut end to the chassis with a couple of u bolts and flex it up dont go too long though mine end above the diff and seem too work ok
Vehicle: 2018 DMAX
Post Posted: Thu Nov 24, 2011 9:20 am
Should be a whole thread in here somewhere with 3/4 stuff.. Was a good one untill ssssssssssssssierra got in there and started dribbling shit but some useful info.
Vehicle: 02 jimny
Could you please post a pic? How many leafs do i need to use? Is it just the top one.
Edit: i guess the skys the limit then cause not much else is legal
Post Posted: Thu Nov 24, 2011 9:32 am
Just one main.
Post Posted: Thu Nov 24, 2011 9:33 am
http://www.auszookers.com/index.php?nam ... elliptical
Vehicle: ute
Post Posted: Thu Nov 24, 2011 9:55 am
Check tomorrow ill take a pic on the morning
I have one spring but when my new ones arrive I'm going to try a couple
As they 3/4 spring dosnt allow the main pack to flex at all
I'm hoping the increased rate in the 3/4 spring will force the full spring to work more as it out flexes or more aptly out droops the front. I will post if it works
Vehicle: 02 jimny
Post Posted: Thu Nov 24, 2011 10:08 am
Awesome please keep me posted. thanks for all the help so far boys...
Vehicle: 02 jimny
Post Posted: Thu Nov 24, 2011 8:49 pm
Do you gain any height outta the 3/4. Cause i like my current height
Post Posted: Thu Nov 24, 2011 10:57 pm
No. 1/4 spring should sit flat against the chassis rail and thus shouldn't increase your static ride height
Lil Foot!
Post Posted: Thu Nov 24, 2011 11:22 pm
607CHA What springs are you running now?
If the diff is level with the chassis,Horizontal, Not flexing. If you were to lower the arse to the bumps, How much shock travel will you have left?
How much room is in the guards when flexing?
How much bumpstop are you planning to cut out?
Good work guys. Bumpstop mods, story is now 1/4 epp..
Vehicle: 02 jimny
Post Posted: Thu Nov 24, 2011 11:33 pm
Running 2inch king springs in rear. and shocks aren't in yet. Was planning 15-20mm cut of bumpstops. and about 50mm or so of clearance. im running 30" tyres on -13 rim
Vehicle: 02 jimny
Post Posted: Thu Nov 24, 2011 11:34 pm
Vehicle: 02 jimny
Post Posted: Thu Nov 24, 2011 11:35 pm
Post Posted: Fri Nov 25, 2011 12:10 am
Cannot believe no one has said it yet !
Your wheels are to small if they aren't rubbing
Post Posted: Fri Nov 25, 2011 12:20 am
Is there a reason you put the bodylift in?
The whole point of this is to fill a gap?
Vehicle: 02 jimny
Post Posted: Fri Nov 25, 2011 12:36 am
Body lift was put in for height. if i knew back then what i know now ot wouldn't be there. it does help with some stuff.
Post Posted: Fri Nov 25, 2011 12:56 am
So now i guess it depends on what YOU want.
Are you happy on how it handles offroad now?
Vehicle: 02 jimny
Post Posted: Fri Nov 25, 2011 1:08 am
I don't like how it lifts a rear. will the top leaf from the front pack work?
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Fri Nov 25, 2011 1:09 am
I vote take out the body lift and get lockers.
Users browsing this forum: No registered users and 291 guests
