It is currently Wed Oct 07, 2026 4:17 pm
Post Posted: Sat Nov 26, 2011 12:54 am
i have a 99' jimny and was wondering is it worth taking on the beach if so wat would be some good rust proofing be?
Post Posted: Sat Nov 26, 2011 12:56 am
If you want to take it on the beach then it may be worth it. Hose it out when you get home.
Post Posted: Sat Nov 26, 2011 1:11 am
If you want to see North shore, Rainbow or Fraser then YES it is worth taking the Jim as it's a hell of a lot easier than walking.
For rustproofing I use a mix of :
25% new engine oil (thicker the better)
25% new trans fluid.
50% cavity wax.. (available at supercrap)
Spray this mix everywhere you can get it in the body, and leave to drip overnight. Next day, go for a long drive on a dirt road to get a good coat of dust on everything to seal it so sand doesn't stick everywhere when you hit the beach.
Beach driving....
Keep left.
Lower tyre pressures help.. EG 60% of road pressure.
When parking for a look or fish, reverse up to the dune facing the beach so people driving up and down the beach can see from a distance that you are stopped and not a moving vehicle.
Post Posted: Sat Nov 26, 2011 1:55 am
SO YOU JUST MIX IT UP AND SPRAY IT ON, CAN YA PUT IT ON WITH A SPRAY GUN OR IS IT TO THICK. FKN CAPS.
Post Posted: Sat Nov 26, 2011 2:07 am
Just use one of those little plastic spray bottle things.
Post Posted: Sat Nov 26, 2011 3:07 am
I use a very cheap sandblasting gun with a hose over the nozzle to insert into door and panel cavities.
It may be worth drilling a few extra holes in the pillars (in inconspicuous places) to get proofing in there. Plug the holes with little bungs from Clark rubber or similar.
Post Posted: Sat Nov 26, 2011 4:14 am
i use that multi-purpose spray under mine..
no rust yet.. $3 or so
green can at supercheap.. it claims rust prevention soo?
If in doubt power out!
Post Posted: Sat Nov 26, 2011 7:49 am
I used pale boiled linseed oil from bunnings. it's taky for a couple days but then drys out. a mate has a few boats and thats what they use to spray there trailers etc with.
Users browsing this forum: Google [Bot] and 150 guests
