http://auszookers.com/forum/
Need help with spring length
http://auszookers.com/forum/viewtopic.php?f=5&t=28134
Author:  ablouse [ Tue Nov 29, 2011 1:08 am ]
Post subject:  Need help with spring length
G'day I'm fitting new springs, I've got a ruf but the rears are too short
Any know of a spring that is a couple of inches or so longer that would suit a 2" lift? Ive been quoted $200 per pack for customs from Westcoast which is too much.
Author:  BlueSuzy [ Tue Nov 29, 2011 1:10 am ]
Post subject:  Re: Need help with spring length
Have a good read
http://www.auszookers.com/index.php?nam ... 74&start=0
Author:  ablouse [ Tue Nov 29, 2011 2:10 am ]
Awesome cheers
Author:  JrZook [ Tue Nov 29, 2011 2:29 am ]
What rears are you running at the moment that are too short?
Author:  Gwagensteve [ Tue Nov 29, 2011 2:58 am ]
There's no such thing as too short for a car with 3/4- just slide the 3/4 spring up a bit. Shackle angle is adjustable.
Ps the car was set up on ome, don't know what's in it now.
Author:  ablouse [ Tue Nov 29, 2011 3:04 am ]
Sorry that post was misleading the standard length
Rears are to short for the front ruf
Author:  JrZook [ Tue Nov 29, 2011 3:14 am ]
Off the shelf EFS rear mains are ~1040mm. Significantly longer than std rears
Author:  Gwagensteve [ Tue Nov 29, 2011 5:15 am ]
Your car has the longest extension I ever did- it was ruf#1 Circa 1998 :D - 100mm (!) i am down to 35mm now with 2" on the bumpstops when I do a ruf. I'd slide the shackle hanger back about 60mm, if you don't know someone who can weld, try efs packs or look at custom.
Steve
Author:  ablouse [ Tue Nov 29, 2011 8:16 am ]
Steve
I really appreciate the info. The only reason i want to go longer is the shackle hits the stop after about 15degrees of movement and the static position is already short of vertical. I like the idea of longer springs and was thinking i could pull the diff forward a little more do you see any problems there? welding is no problem either if that is a better option, I think youre original ome springs are still in it, the fronts arnt too bad but the rears are stuffed, 13 years not a bad lifespan it looks like its been used pretty hard :D
