It is currently Wed Sep 23, 2026 4:32 pm
Post Posted: Tue Nov 29, 2011 4:51 am
I have a Sierra and the engine is playing up and I cannot work it out. It has been running a bit rough the last few weeks but nOt too bad and now it starts ok and revs fine but as soon as I out it into gear and take off it coughs and splutters and stalls ever time. It's 13ba engine any suggestions on what it is?
Vehicle: 1995 Sierra 1.3
Post Posted: Tue Nov 29, 2011 5:00 am
Possibly some crap in carby - clean out crap from carby and possibly replace fuel filter if it hasn't been changed for a while.
http://auszookers.com/index.php?name=Fo ... 984#503984
Post Posted: Tue Nov 29, 2011 5:15 am
x2 on fuel filter.
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Post Posted: Tue Nov 29, 2011 6:56 pm
Thanks guys will try that today and see how it goes
Post Posted: Wed Nov 30, 2011 2:08 am
Ok gave that a go cleaned out the fuel replaced the filter runs well on idle and Erving but as soon as load is put on it shudders and coughs then stalls. Found that if I either push the gear stick had to the drivers side or if I grab the engine and pull it to drivers side it do this. Possibly when the engine twists it wants to stall like this hence when I go forward it stalls but if I run in reverse it dose now? Any suggestions now I'm all ou of ideas
Vehicle: 4wd
Post Posted: Wed Nov 30, 2011 2:28 am
Sounds like your grabbing third and not first.
Try starting off in second and see if that helps.
Watch out or you'll get sued.
Post Posted: Wed Nov 30, 2011 3:17 am
Nah I'm pretty machenicaly minded it's when u grab the whole engine and pull it drivers side over so like the engine has load when I'm taking off and it dose it then and when I put pressure on the stick which twists the gearbox slightly it dose the same thing. It dose it in any gear I take off except reverse for some reason so all forward gears. Go figure....?
Post Posted: Wed Nov 30, 2011 3:38 am
I would say an electrical connection of some sort has come loose and the movement of the engine causes it to lose contact, stalling the engine.
Vehicle: 4wd
Post Posted: Wed Nov 30, 2011 3:41 am
Sorry I misread your post.
Check your engine mounts.
Vehicle: SJ70 1993
Post Posted: Wed Nov 30, 2011 8:49 am
I had same problem and it was a dodgey coil. It started as load in reverse would stall then after awhile it did it to first. The bad coil not making a strong enough spark for it to kick over underload (what my brother sad i think). New coil in runs like a dream
Hope that helps
Lock, Drop and roll
Post Posted: Wed Nov 30, 2011 11:43 am
ok cool thanks shiv, that sounds about right ill have a look at replacing the coil and maybe even leads they look a bit old and see how it goes thanks
Vehicle: SJ70 1993
Post Posted: Thu Dec 01, 2011 2:27 pm
Yeah i did leads aswell
Lock, Drop and roll
Post Posted: Mon Dec 05, 2011 10:43 am
Hey shiv wOrked like a charm! Replaced the coil and leads and drives like a dream! Thanks a lot guys the zook lives another day
Vehicle: SJ70 1993
Post Posted: Tue Dec 06, 2011 12:03 am
Cheers no worries glad to help
Lock, Drop and roll
Users browsing this forum: No registered users and 169 guests
