http://auszookers.com/forum/
who has put a 1ltr T/case in a coil sprung sierra??
http://auszookers.com/forum/viewtopic.php?f=5&t=2815
Author:  hooki [ Fri Aug 22, 2008 8:55 am ]
Post subject:  who has put a 1ltr T/case in a coil sprung sierra??
hey guys.
I'm just after some info about fitting a 1ltr sierra transfer case into my coily. I'v been told that it's not as easy as putting one into a 1.3 leaf sprung sierra....so i'm just wondering what parts i will need to do the full install and how difficult it is?? Any info would be great.
cheers.
Author:  hooki [ Tue Aug 26, 2008 7:13 am ]
Post subject:  Re: who has put a 1ltr T/case in a coil sprung sierra??
Author:  mrw82 [ Tue Aug 26, 2008 8:43 pm ]
if you get the brackets with the case it should fit up ok, flanges will need to be swapped so make sure the 1 litre case has the 4wd light switch as the earlier models aren't interchangeable. also I think the jackshaft is different or needs to be shortened, may be able to use 1.3 leafy shaft.
dont treat this info as gospel, this is just what I have picked up from reading other info.
