It is currently Fri Sep 25, 2026 11:07 am
Vehicle: Vitara G16b , Sierra G16b
Post Posted: Thu Dec 01, 2011 4:09 am
Gday all, having a bit of trouble with the check engine light and alternator light.
When I connect violet yellow A14 and ignition pos the light doesnt come on? Also I dont have a alternator charge/battery light when ignition is on. The stock Sierra green plug is connected to the G16b alternator and all wires are fine going to the dash. Any ideas?
Post Posted: Thu Dec 01, 2011 5:52 am
Ok update*** Alternator and other lights work! swapped pins on large plug behind dash to drover locations. It's a drover dash cluster but who would of thought the wiring/pins are slightly different to sierra.
Still stuck on the Check engine light! The Violet/yellow does nothing....
Post Posted: Thu Dec 01, 2011 10:35 am
No one? I gather the Violet/Yellow wire from the ecu switches the earth on for the globe correct?
Post Posted: Fri Dec 02, 2011 1:47 am
Fixed. Ecu wasn't getting power got a couple of pins wrong on the relays.
Please close or delete.
Post Posted: Fri Dec 02, 2011 2:02 am
:D. Top work mate. I wish I could have helped ya but I brought a Baleno conversion basically bolt in that came out of a seirra.
Users browsing this forum: Google [Bot] and 265 guests
