It is currently Fri Sep 25, 2026 5:48 pm
Post Posted: Thu Dec 01, 2011 7:59 am
G16B.. J20... H20/25/27 Bellhousings.... Does anyone know if any or all of them are the same bolt pattern?
Thinking the buggy might need more power than a G16B can deliver... H25 would be nice if it'll bolt up... :D
I currently have a G16B with a Vit manual bellhousing bolted to a hilux gearbox with an adaptor.
I want to know if the engine block OR the gearbox flange on the bellhousing is same for these engines.
Post Posted: Thu Dec 01, 2011 8:13 am
Dont quote me on this but as far as I know J20a is the same as G16b but the flex plate is different to the G16b
What have you already got?? Aw4 from a g16b vit??
Post Posted: Thu Dec 01, 2011 8:15 am
Sorry.. First post edited.
Post Posted: Thu Dec 01, 2011 8:40 am
Been told the same thing, but never tried
H is nothing like it....
Post Posted: Thu Dec 01, 2011 8:42 am
What about the gearbox to bellhousing pattern? Are they the same?
Post Posted: Thu Dec 01, 2011 9:18 am
lose you suzuki stuff and adaptor and run 3rz or 4age
Post Posted: Thu Dec 01, 2011 9:20 am
Isn't H the same as Lux..... :?
Post Posted: Thu Dec 01, 2011 9:53 am
3RZ is tempting... Even a Hiace 2RZ would be great but it is pushing the ability to still call it a Suzuki.
Mind you an RZ is almost a bolt in fit now. :? :?
Post Posted: Thu Dec 01, 2011 10:12 am
not sure if this is any help...
taken from 303zuke's Vitara box/Hilux transfer thread, quitea few pics... http://auszookers.com/index.php?name=Fo ... pic&t=9848
303zuke wrote:
The bellhousing and input shaft will fit a 2.5 V6 and the 2.7 V6. Although not used with this gearbox, I understand the 2.0 V6 has the same bolt pattern and will fit this bellhousing.
The bellhousing to gearbox pattern is one of the more common adapter types available. For stock factory engines, you could choose from the Suzuki 2.0 V6, 2.5 V6, 2.7 V6, Toyota 2.2lt L, 2.4lt 2L, 2.8lt 3L, or 3.0lt 5L Diesels. Any of the bellhousings used with the W series boxes and Petrol Y family of engines will also fit. Mazda RF 2.0lt Diesel, Peugeot 2.0lt Diesel. Jeep 4.0lt straight 6 or 2.3 4 cyl.
Aftermarket adapters are also made to this pattern for Holden V6 and V8 and Red 6 cyl, and even the vintage Ford Sidevalve V8!!
kit
Post Posted: Thu Dec 01, 2011 8:12 pm
Thanks Gus...
Looks like I'm looking for a bellhousing to try.
Users browsing this forum: Google [Bot] and 367 guests
