It is currently Wed Sep 23, 2026 6:36 am
Vehicle: Tin Top
Post Posted: Sun Dec 04, 2011 9:58 pm
Is it possible to use clutch cable from earlier model sierras on SJ80?
Clutch cable has seen better days and has pushed out the side of cable sleeve and earlier model ones are readily available, the SJ80 on the other hand is not so common.
Any help or advice appreciated.
Richard T
Vehicle: SWB GV
Post Posted: Sun Dec 04, 2011 10:59 pm
I broke mine a couple of months ago and wondered the same thing. I did a bit of research and it appeared that the coily cable has a different mounting or something similar (someone please correct me). End of the day, had to use a coily one as the leafy ones didn't fit.
Try www.suzistore.com.au or your mechanic. Mine was able to source one within a day, despite the lack of supply.
Brodie
Post Posted: Sun Dec 04, 2011 11:39 pm
u need bracket for the block and they dont quite work as well on the firewall.
let me know if u need any bits rich?
Post Posted: Mon Dec 05, 2011 2:05 am
I have one coily cable here... $40 delivered.
Users browsing this forum: Google [Bot] and 180 guests
