It is currently Mon Jul 27, 2026 4:57 pm
Vehicle: sierra, 31's, 6.5's
Post Posted: Sat Dec 03, 2011 2:39 am
i am trying to replace the front and rear main seals, but i am stuck trying to get of the centre crank bolt.
any tips on how to do it
Post Posted: Sat Dec 03, 2011 3:08 am
turn it left?
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Sat Dec 03, 2011 3:11 am
yeh im not stupid. its really tight, the rattle gun wont undo it, i was wondering if there was a special way to do it
don't follow me, you won't make it
Vehicle: '95 lwb vitara
Post Posted: Sat Dec 03, 2011 3:15 am
Rostoff.
Vehicle: Yellow Ute
Post Posted: Sat Dec 03, 2011 3:18 am
Just double check before you do it, but put the spanner on and run a pipe down to the floor then hit the key it should spin the right way to undo it... Then go back to your rattle gun... Then swing off it for a while... Then come back tomorrow and you'll undo it with your fingers :roll:
Vehicle: LJ80
Post Posted: Sat Dec 03, 2011 3:31 am
yes the starter undid mine took a couple of hits though and a rattle or two
Post Posted: Sat Dec 03, 2011 4:24 am
The engine is out if the car but
Post Posted: Sat Dec 03, 2011 5:02 am
Make something to lock the crank to the block. Figure a way to hold the engine block so it doesn't move, then get your breaker bar with a length of pipe on it to undo it
Post Posted: Sat Dec 03, 2011 5:03 am
x2 if that doesn't work, get a longer breaker bar and a longer pipe
helloo
Post Posted: Sat Dec 03, 2011 5:06 am
all this but once the crank is locked use the rattle gun, they arent effective when the crank can move around
Post Posted: Sat Dec 03, 2011 5:33 am
& if that doesn't work, get a new rattle gun, or oil your's....
Post Posted: Mon Dec 05, 2011 5:42 pm
And there are rattle guns and rattle guns. If your using a $50 supercrap 'bargin', you may as well try undoing it with your teeth. A few drops of oil every now and then can do wonders for a rattle guns usable life span.
Users browsing this forum: Google [Bot] and 326 guests
