It is currently Sun Oct 04, 2026 3:14 pm
lesspostingmorewheeling
Post Posted: Tue Aug 26, 2008 4:48 am
on a WT diff are the brackets that stop the ubolts moving sideways the same on both sides?
the drivers side was fine and everything bolted up alright but on the passanger side the bracket is different and when one ubolt is on the other one doesn't line up has anyone else had this problem? or am i just doing something wrong again? :roll:
cheers
Post Posted: Tue Aug 26, 2008 1:13 pm
The brackets are different to suit the off-set diff head aren't they?
Vehicle: 75 Cruiser
Post Posted: Tue Aug 26, 2008 1:30 pm
if you mean a far bit different then yeah the U bolts are different sizes.
if you mean a couple mm different, then yeah sometimes you have to squeeze the U bolts together to get the ends in the holes.
Post Posted: Tue Aug 26, 2008 9:21 pm
it can be a bit fiddly to get them all in, a vice is your friend for bending them in a bit so they line up. dont force them in with a hammer or something though as you might ruin the thread.
Post Posted: Tue Aug 26, 2008 10:17 pm
just give the u bolts a good squeeze and they will go back in.
Post Posted: Wed Aug 27, 2008 1:13 am
i mean the brackets on top of the diff housing that the ubolts fit over
Vehicle: Zookless
Post Posted: Wed Aug 27, 2008 1:37 am
Yeah, they are slightly different Mike. I can't remember which, but one side looks like it will just slip off. Don't worry, it won't.
Edit: here's some pics :wink:
Driver's side:
Passenger's side:
Post Posted: Wed Aug 27, 2008 1:45 am
i didn't have trouble with that side but on the other side when i put one ubolt in the groove in the bracket the one on the other side of the bracket doesn't line up
Users browsing this forum: No registered users and 187 guests
