http://auszookers.com/forum/
Starter Motor Rebuild.
http://auszookers.com/forum/viewtopic.php?f=5&t=28385
Author:  CairnsZook [ Wed Dec 07, 2011 12:36 am ]
Post subject:  Starter Motor Rebuild.
My starter motor wasn't engaging with the flywheel properly.
So I decided to pull it apart.
First take out the long screws:
Yep, it's a little dirty:
Then after you've taken off the solenoid, you can take it apart:
:?: At step two, a little ball bearing fell out. You can see it in the third pic. Can anyone tell me where it came from?
And what grease should I be using when I put it back together? I've got bearing grease and molly grease here.
Author:  boostedbrick [ Wed Dec 07, 2011 12:43 am ]
Post subject:  Re: Starter Motor
That ball bearing sits on the end of the shaft on the bit on the right hand side in second pic off the top of my head.. I know it sits on the end of one of the shafts..
I like to use a fine layer of moly grease on the motor itself and PTFE on the solinoid.. I pull mine down and clean it atleast every 5 or 6 months..
Author:  CairnsZook [ Wed Dec 07, 2011 12:49 am ]
Cheers,
It fell out as I separated the motor section from the geared section. So it makes sense that it came off the end of the motor's shaft.
Author:  CairnsZook [ Wed Dec 07, 2011 2:52 am ]
I took the end of the motor off to have a look. It was just a little dusty in there. Pretty good, considering how long it spent underwater on the last trip!
So, it's all lightly greased, back in the car and working beautifully :D
Oh, this is one of the narrow-body, reduction-type starters from eBay if anyone is wondering. It's been in for over a year now, and is in good nick, considering the abuse it cops.
Author:  steak_knife [ Wed Dec 07, 2011 6:40 am ]
Link please!!!! :D
Author:  CairnsZook [ Wed Dec 07, 2011 7:14 am ]
Here you go Mr. Steak :D
LINKY
