It is currently Wed Oct 28, 2026 10:50 pm
Post Posted: Wed Dec 07, 2011 5:32 am
Hello fellow zookers I'm in a sticky spot at the Moment with my conversion the cast 1300 engine mount thing is supposed to fit the 1600 block with a little filling I'm using the bent kit from here I'm stuck on what to do any help I would be very appreciative thanks guys and girls
Post Posted: Wed Dec 07, 2011 6:27 am
U need the 1.3 ltr fly wheel otherwise ur gear box is to small to fit over the 1.6ltr flywheel that what ur talking about?
Post Posted: Wed Dec 07, 2011 6:34 am
From memory they almost bolt straight to the block, I can't remember having to mod the 1.3 mount's to fit the 1.6 block.
Have you tried bolting them on?? Left & right are different...
& as the post above, 1.3 flying wheel & clutch.
Post Posted: Wed Dec 07, 2011 6:41 am
I have just cut the mounts off a 1.3ltr bolt them onto the motor line the motor up in the car and weld the mounts in place
Post Posted: Wed Dec 07, 2011 6:42 am
1.3 mounts bolt straight onto the block.
Post Posted: Wed Dec 07, 2011 7:06 am
Thanks for the flywheel trying to put the motor and box together getting there slowly but the inlet manifold side bits are different exhaust side is goodos the inlet side needs a fair whack taken off it the instructions says only 1 mm pretty confused at the moment
Post Posted: Wed Dec 07, 2011 9:34 am
Still trying to figure it out got a die grinder today (not sure if that's how it's spelt) so if you take a fair whack off it is it still ok?
Users browsing this forum: No registered users and 318 guests
