It is currently Thu Nov 05, 2026 9:30 am
Vehicle: 1.6 Sierra locked and lifted
Post Posted: Wed Dec 07, 2011 8:19 am
This question has probably been asked before but, Do you need an engineers certificate in Victoria for a 1.6ltr carburetor powered Sierra?
If so does anyone know any lenient engineers in the Dandenong or Mornington area?
Post Posted: Sat Dec 10, 2011 8:13 am
Nope just take new engine number in, same as EFI.
Too easy. :D
Post Posted: Sat Dec 10, 2011 8:26 am
Yes. It's not a replacement or factory available engine in that model.
Post Posted: Sat Dec 10, 2011 8:45 am
You do not need an engineers certificate. I have done 2 cars, you just take in new engine number and a receipt for the motor.
If the engine mounts haven't been modified, increase in engine size not significant, and motor from same manufacturer, you do not need an engineers certificate.
Hope this helps. Cheers.
Post Posted: Sat Dec 10, 2011 9:00 am
Sorry, that is just wrong. It's a conversion.
I am also aware of car that had a G16a fitted and registered. It was done by stealth.
*bring bring* hello, Vicroads how can I help you?
Yeah, I'd like to inform you I've changed my engine number to g16a14766
"ok, your details have been updated"
You can ring Vicroads and tell them whatever you like. Try and get a rwc on that car to transfer ownership and you'll have to do the same fancy footwork as the guys that I know that did it.
The rules are clear. A g16 is more than 10% more powerful than the stock engine, the engine mounts do have to be moved, and it wasn't an engine offered in that model.
Post Posted: Sat Dec 10, 2011 9:06 am
No probs, my engine mounts weren't modified, engine was put in before roadworthy was taken to Vicroads, and presto done legit and it's a G16B.
Maybe I was just lucky both times. Kewl.
Post Posted: Sat Dec 10, 2011 12:01 pm
Thanks guys, i suppose its the last piece to my Suzuki puzzle. Anybody know a lenient engineer in the dandenong area?
Post Posted: Sat Dec 10, 2011 12:10 pm
Your story paints a picture that is so far from legit its not funny. A RWC won't stop a Vic roads or police officer from labeling your vehicle defective. You have not gone through the appropriate channels to get your motor approved.
Mate you don't need a lenient engineer. That motor is well within the allowable power/ cubic increase limits. just call Vic roads and ask them who the closest approved engineer is to you.
Post Posted: Sat Dec 10, 2011 12:24 pm
The reason i say lenient is because of the rest of the car, 2" body lift 2" extended spring hangers and 2" suspension lift kinda makes it a bit dodgy
Post Posted: Sat Dec 10, 2011 7:22 pm
A 2" suspension lift and 2" BL are fine with an engineer, so long as the BL has been well executed and the blocks are steel or alloy.
Take out the extended spring hangers. You don't need them anyway and it's very unlikely the engineer will pass them.
Post Posted: Sat Dec 10, 2011 10:22 pm
Ok, thanks everyone for the advice.
Users browsing this forum: No registered users and 55 guests
