It is currently Tue Oct 27, 2026 9:36 pm
Post Posted: Wed Dec 07, 2011 8:39 am
could anyone please give me some tips on replacing vitara CV's i would really help. thank you
Vehicle: LWB Sierra & XL7
Post Posted: Wed Dec 07, 2011 8:49 am
The main thing is to disconnect anything to the hub / brake assembly, you don't have to remove too much but as a minimum and to make things easy I remove the struts, tie rod end and move the brake caliper out of the way, enough for everything to swing away and jiggle the CV out of the hub.
The tricky and fun bit is using a strong screwdriver or small prybar to squeeze the CV away from the diff, be careful, it's easy to damage stuff especially the alloy diff.
It's a pain of a job but rewarding to know that you will save a couple of hundred bucks by DIY.
'92 Vitara & Camper trailer
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Wed Dec 07, 2011 8:58 am
I found this a great help. Thanks to the legendary Atari4x4
http://auszookers.com/index.php?name=Fo ... ic&t=12526
Passenger side is easy. The drivers side's more hassle, but if I can do it anyone can. :lol:
Post Posted: Wed Dec 07, 2011 7:56 pm
Thanks guys :D
Users browsing this forum: No registered users and 409 guests
