| tyre size http://auszookers.com/forum/viewtopic.php?f=5&t=2848 |
| Author: | zukigeorge [ Thu Aug 28, 2008 7:33 pm ] |
| Post subject: | tyre size |
What size tyres can I fit to my 93 vitara 4 door that won't change the gearing to much or through to much load on bearings and cv's. It gets used for general highway use as well as fire trails. I have 2'' suspension lift and will add 2" body lift in the next few weeks. |
| Author: | joeblow [ Thu Aug 28, 2008 7:35 pm ] |
| Post subject: | Re: tyre size |
235's or 30inch tyres. |
| Author: | zukigeorge [ Thu Aug 28, 2008 7:39 pm ] |
Thanks mate - I guess they would be better on sunraysia rims, but what size rim? |
| Author: | jimbo_jones [ Sun Aug 31, 2008 1:07 am ] |
I would use a 15x 8 rim try a f100 off set |
| Author: | joeblow [ Sun Aug 31, 2008 1:30 am ] |
watch out for f100 rims in the 8 inch size as the offset my be a problem. the more offset the more likely the tyre is going to foul on the rear arch lip as offset increases the movement within the turnig arch. with a tyre like a 235 or 30 a 7 inch sunny with no offset should be better. but if you have a suspension and body lift and 8 inch rim should be ok, but might be a bit wide for that size tyre. |
| Author: | zukigeorge [ Sun Aug 31, 2008 5:27 pm ] |
Thanks - I will do the body lift and then start to look at tyres and rims. Cheers |
