| Author |
Message |
Emily.1
Joined: Thu Nov 10, 2011 12:46 am Posts: 12 Location: Ipswich
 Posted: Sun Dec 11, 2011 6:05 am |
I have a 1991 1.6lt EFI vitara, 4spd automatic... It wont go into 1st gear, or overdrive, and even after we have had 1st for a while we are constantly loosing it while 4wdriving..Please Help Its Driving me mad!!
runtbase
Joined: Wed Nov 04, 2009 10:30 pm Posts: 223 Location: Bundaberg
Vehicle: Serria
 Posted: Sun Dec 11, 2011 6:13 am |
Buy a Serria and put the motor in it and bolt the 5 speed up to it. Way better car then those vitara hairdresser cars. Lol.
_________________ Sj80 cab on sj70 chassis 5inch lift 1.6 turbo inte
TheOtherLeft
Joined: Sun Aug 27, 2006 11:30 pm Posts: 818 Location: Sydney
 Posted: Sun Dec 11, 2011 6:52 am |
Have you checked the fluid levels? Does it smell burnt?
_________________ 2002 SWB GV
Lifted and Locked
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Sun Dec 11, 2011 9:20 am |
As stated, check fluid level first. Next step then should probably be a fluid and filter change.
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Sun Dec 11, 2011 9:30 am |
Scrawn wrote: As stated, check fluid level first. Next step then should probably be a fluid and filter change.
X2.....
Talking to you today, that's the 2nd time you've run it out of fluid, auto's don't like that & need to be "run through" to get the fluid level correct.....
Or you could just ban your BF from driving it...
_________________ I used to be indecisive,
Emily.1
 Posted: Tue Dec 13, 2011 6:43 am |
its not the fluids.. we have played with the fluid levels and its had brand new fluids put in it twice in last 2months.. we have had the transmission flushes... worked a little smoother for a bit then went back to shit..
Emily.1
 Posted: Tue Dec 13, 2011 6:45 am |
the boyfriend is a better driver then i am...
Scrawny
 Posted: Tue Dec 13, 2011 6:59 am |
Have you taken the pan off? The pick-up may be full of shit? I haven't had a pan off one of these ones before but the pick-up is usually also a changeable filter
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Tue Dec 13, 2011 7:48 am |
Run the trouble codes for the auto? 2-3 only is "limp home" IIRC.
