| flex http://auszookers.com/forum/viewtopic.php?f=5&t=2859 |
| Author: | seen [ Fri Aug 29, 2008 11:35 pm ] |
| Post subject: | flex |
i hav got a set of 2 inch lifted efs springs n i am wondering if i take a leaf out will it inprove my flex n how much lower would it make my car sit i jst want to see if it would be worth it or not any hello would be good thanks |
| Author: | steve [ Fri Aug 29, 2008 11:42 pm ] |
| Post subject: | Re: flex |
I have 2inch lifted King springs in my stocker sierra. I took the load leaf out (short fat bottom one). It sits about the same, maybe a flys dick lower. Has improved the softness of ride a bit, which was what i was after. Not sure about flex yet. |
| Author: | BlueSuzy [ Fri Aug 29, 2008 11:44 pm ] |
How many leafs are in each pack? Alot of the time, removed spring doesnt actually improve the flex that much, It more improves comfort of the ride.. The height generally doesnt sag too much. If at all depending on which ones are removed. |
| Author: | CairnsZook [ Sat Aug 30, 2008 12:21 am ] |
This one might help ya http://www.auszookers.com/index.php?nam ... ing+leaves |
| Author: | MART [ Sat Aug 30, 2008 12:40 am ] |
Why do you need more flex , is there a reason , I know the answer , but modifying the springs will not give you the outcome your looking for , it may help a little , you are probably loosing your drive as your suspension travels , you need to get some sort of traction aid , you will be suprised how much further your zuk will go , Cheers Paul. |
| Author: | lump_a_charcoal [ Sat Aug 30, 2008 2:43 am ] |
would fitting bumpstops help more then? |
| Author: | seen [ Sat Aug 30, 2008 12:22 pm ] |
yeh i no wat u mean i would lov a airlocker i jst havnt got the money for it yet |
