http://auszookers.com/forum/
help i need to lower my gears abit
http://auszookers.com/forum/viewtopic.php?f=5&t=2860
Author:  bazook [ Sat Aug 30, 2008 12:36 am ]
Post subject:  help i need to lower my gears abit
ive just bought 6.5.1 transfer gears and i have 32 x 12 x 15 tires and all this is in a wt so ive got 3.7 diff gears
now problem i have is i wondering if i put in nt diff gears in will this bring my revs down a bit cause on the higway at 110 revs are at 3,700rpm
Author:  royce [ Sat Aug 30, 2008 12:42 am ]
Post subject:  Re: help i need to lower my gears abit
no it will rev more, 3700 is a pretty sweet spot for a sierra anyway
Author:  steve [ Sat Aug 30, 2008 12:49 am ]
110 KPH in a Sierra!!?? :shocked:
i'd be more worried about keeping it in one lane rather the revs :lol:
Author:  joeblow [ Sat Aug 30, 2008 1:58 am ]
anywhere between 3600 and 4000 rpm is fine.
Author:  lump_a_charcoal [ Sat Aug 30, 2008 2:21 am ]
Anywhere between the gutter and median is also fine...
Author:  just_cruizin [ Sat Aug 30, 2008 2:36 am ]
That's why I tell people Sierra are that small, they need to be to keep them in one lane
Author:  BlueSuzy [ Sat Aug 30, 2008 2:45 am ]
wtf are u guys on about, the rough roads mine doesnt follow much more then my civic on 18"s..
My 1.6, 6.5.1, 33'x12.5 @ 130km cruise wit 1 finger comfortable smooth roads....No p/steer..want more go? Still enough revs to drop into 4th....
Author:  Mike [ Sat Aug 30, 2008 2:48 am ]
i've seen a 1.3 sierra with 31s and standard gearing do 120
Author:  BlueSuzy [ Sat Aug 30, 2008 2:51 am ]
Mate has been booked stocker at 138Km hr....Downhill prob with a tailwind :lol:
Author:  Mike [ Sat Aug 30, 2008 3:04 am ]
slip streaming helps too :lol:
Author:  hooki [ Sat Aug 30, 2008 8:38 am ]
complete stock coil sprung zook at 150kph was the fastest i could get it...lol. in a safe and legal environment of corse.
Author:  royce [ Sat Aug 30, 2008 10:31 am ]
140 in a 1 litre 4 speed with 31's and stock gearing :)
Author:  bazook [ Sat Aug 30, 2008 12:08 pm ]
170km in safe conditions (on dyno)thats with stock tires without geared transfer case and with a 120hp gti turbo in front
thanks guys for the info
Author:  Damo [ Sat Aug 30, 2008 1:54 pm ]
I doubt it would ever be able to do that on the road. 170kph and the bricklike profile of the Sierra body causes a lot of deag.
Author:  norm [ Sat Aug 30, 2008 2:24 pm ]
aww the momries of going fast in a zook.
when i first got her, used to get 130 to 140km/h on the clock easy.
thats rollen on 35s, so its out about 25kms..
now with this stock vit motor only gets up about 90 max on the clock..
5th gear on 2700rpm
Author:  Hybrid [ Sat Aug 30, 2008 4:33 pm ]
I'm with Bluesuzy here. I used to do 100km a day on the M1 at 110-120kmh. When I first got it it wandered a bit but mainy due to the wind. I put in some caster wedges and the 15000kms since she drives straight as an arrow. the wind blows the body around on the swprings but it still tracks straight.
With my 30s and transfer gearing 100-120kmh = 3500 - 4000rpm. Wouldn't mind dropping them a little though as 3500 is where it starts making a hell of a racket. I'm hoping the bigger tryres brings it down to the 3200-3300 mark.
Author:  lump_a_charcoal [ Sat Aug 30, 2008 4:47 pm ]
caster is front to back right?
Author:  Damo [ Sat Aug 30, 2008 5:17 pm ]
Unfortunately the torque peak is closer to the 4000rpm mark, but with the 1600 you should be OK.
Author:  Damo [ Sat Aug 30, 2008 5:29 pm ]
Yep
Author:  Hybrid [ Sat Aug 30, 2008 5:42 pm ]
Yeah front to back. Technically my steering plain is higher at the front and lower at the back than stock. I got hilux wedges from snake racing and cut them down but I found superior engineering ahd them ready made for the zuk when I put them in my GF's sierra.
Author:  joeblow [ Sat Aug 30, 2008 7:17 pm ]
5th gear on 2700rpm
8O ...5th gear 2700...90k's....definately not geared correctly. must go through the juice too...
Author:  bazook [ Sat Aug 30, 2008 7:53 pm ]
what about putting 5.12 gears in the diffs
Author:  norm [ Sat Aug 30, 2008 11:07 pm ]
5th gear on 2700rpm
yhe man she eats it prity hard hey,, its farrkked :x :x
no gearing ATM, just the 4.88s diffs and vit box/Tcase..
soon to get the gearing
Author:  BlueSuzy [ Sun Aug 31, 2008 12:18 am ]
When the caster is out yes it will want to steer all over the place...Mine is sorted i think..
Oh and wind is definately a different story :lol:
But a low brick with heavy wide tyres help..More then a 5"lift on stockers!
Author:  Rockhopper [ Sun Aug 31, 2008 2:07 pm ]
What?!?! Where!?!? Off a cliff??? :lol:
Author:  royce [ Sun Aug 31, 2008 3:01 pm ]
nope flat no wind highway :)
actually it used to cruise on 110 loaded with camping gear too, got bang on 10l 100km as well
it was a freak, you can imagine my disappointment when I 'upgraded' to a slower 1.3 :)
Author:  Rockhopper [ Mon Sep 01, 2008 11:01 am ]
I only ever drove my standard 1.3 to 110km/h. Anything after that would require the use of earplugs to drown out the noise of the screaming motor. Now with 31's on it, it'll still do 110 in 4th, but it takes a while to get there.
